Author: Subject: changing front wheels...
antonio
posted on 15/10/08 at 07:57 PM Reply With Quote
hi there,
maybe a dummy question, but does anyone can tell me how to swap front wheels quickly???
i've got 13 inch wheels, with "large" wings and it's a f**** job to take off the wheels because front wings don't allow the rims to get off!
i know i can unscrew the four bolts on wing stay, but it's too long (going to swap them since my car only goes on track)
if someone here have a good solution to make it easy.... (would like to keep this wings if possible)
next dummy question to follow!!
Canada EH!
posted on 15/10/08 at 08:06 PM Reply With Quote
Just put spacers under the wing bolts, lift the wings up a little higher.
antonio
posted on 15/10/08 at 08:23 PM Reply With Quote
it won't fit! would need to put 3-4 cm spacers!
austin man
posted on 15/10/08 at 08:32 PM Reply With Quote
trim part of the wing edge ??
blakep82
posted on 15/10/08 at 08:34 PM Reply With Quote
smaller wheels
or spacers to lift the wing slightly
or if it ONLY goes on the track, do you need wings?
________________________
TimC
posted on 15/10/08 at 08:37 PM Reply With Quote
Trim the outside edge of the wings right back.
antonio
posted on 16/10/08 at 08:20 AM Reply With Quote
Originally posted by blakep82
smaller wheels
because i do race on wet!
antonio
posted on 16/10/08 at 08:21 AM Reply With Quote
is that what you did tim?
any pictures?
indykid
posted on 16/10/08 at 11:27 AM Reply With Quote
no pics but it's what i did when i had to swap back to an MK cycle wing after one of my dax ones went for flying lessons. took about an inch and a half off all the outside edge.
if you leave the inside edge full depth, it should reduce the tendency for them to flap a bit more.
tom
TimC
posted on 19/10/08 at 11:01 AM Reply With Quote
any pictures?
No, I haven't - I've resigned myself to loosening off the wingstays when I need to change - I couldn't bring myself to mutilate my lovely carbon CSR arches. However, perhaps the best picture of how you might do this is here:
This is the standard MNR arch trimmed to shape.
