sonic
posted on 20/10/08 at 09:40 PM |
Temp sender type
I have a MNR vortx on the top hose there is a steel pipe with a nut/boss welded into it where a water temp sender is supposed to screw in,it looks
like a single wire connection
MNR gave me the supposed sender but when i got home to fit the boss has a 10mm fine thread,the one i got from MNR is about a 25mm thread and two wire
connection.
Has anybody else have one of these on there vortx who can tell me where to get one
Paul TigerB6
posted on 20/10/08 at 09:45 PM |
Sounds like the one you have is for the radiator. Sounds like the boss in the top hose is designed to take a Japanese bike temp sender (they often use
fine threads)
[Edited on 20/10/08 by Paul TigerB6]
GeorgeM
posted on 20/10/08 at 09:50 PM |
are you using a digidash? The nut is for
the temp sensor for this.
Large sensor is for the radiator
GeorgeM
Paul TigerB6
posted on 20/10/08 at 09:51 PM |
Oh - forgot to say the 2001 R1 thermo unit that feeds temps to the ECU must be around 10mm fine!!
sonic
posted on 20/10/08 at 09:52 PM |
No Digidash
Just a temp gauge mounted on the dash panal.
its had one in there before i bought it but the guy cannot remember what type,he said it was supplied by MNR but i don't think it was
GeorgeM
posted on 20/10/08 at 09:58 PM |
If you have a seperate temp gauge, you can get a
sender to fit in the pipe.
Thread size is 1/8 NPTF - look at ETB instruments
website, they also have adaptors to fit other sizes,
and the gauges!
[Edited on 20/10/08 by GeorgeM]
sonic
posted on 20/10/08 at 10:04 PM |
Thanks guy's i will have a look at the ETB site
Krismc
posted on 22/10/08 at 09:41 PM |
I got one from burton power for about £8
