daniel mason
posted on 18/1/10 at 11:14 PM |
offset on a 13" rim?
what offset does a 6" wide 13" rim need to clear the standard sierra front calipers?
and a 7 1/2" rear rim to clear the sierra handbrake caliper? cheers!
adithorp
posted on 18/1/10 at 11:48 PM |
I think it's more to do with the design of the wheel than off-set. Do you have a make and model in mind?
adrian
http://jpsc.org.uk/forum/
v8kid
posted on 19/1/10 at 02:57 PM |
38mm 'aint it?
TimC
posted on 19/1/10 at 03:21 PM |
Daniel
Is this in relation to the MNR? If so, I can help... but they aren't Sierra front calipers so I'm guessing you may be referring to
another car?
TC
daniel mason
posted on 19/1/10 at 06:07 PM |
am going to build another mnr myself and saw the 13" compomotives for sale on here. fronts are et19 and rears et38? anyone help?
tim c. i have had sierra handbrake calipers fitted to rears on my mnr.
[Edited on 19/1/10 by daniel mason]
TimC
posted on 20/1/10 at 09:38 AM |
If you re-read my post, you'll see that I refer to your front brakes only; I'm well aware that you fitted Sierra rears.
Compomotives will give you as good a chance as any. You also need to think about the position in the rear arch.
daniel mason
posted on 20/1/10 at 06:22 PM |
sorry mate never read the post properly! would imagine the et38 rear would be ok but et19 front am not sure?
TimC
posted on 20/1/10 at 07:43 PM |
ET13-19 is normal on a Cortina set-up but I dont know for sure about Sierra.
Ask a direct question in the running gear section, or see if there are old posts in the MK section about 13" rims as they use Sierra gubbins.
daniel mason
posted on 20/1/10 at 08:38 PM |
i would be on cortina uprights but to keep costs down i was going for sierra calipers, or any other which will fit and do a good job of stopping the
car, a second hand pair of R16's or wilwoods is an option also
