Author: Subject: Which radiator for MNR chassis?
prawnabie
posted on 6/11/13 at 11:03 AM Reply With Quote
Hi Guys
Ive got a chance at a couple of different new polo radiators quite cheap. I am assuming that the MNR chassis is standard where radiators + mountings are concered - if so what have you guys fitted and what year/engine size was it from?
I will be using an MX5 donor.
Shaun
adithorp
posted on 6/11/13 at 01:04 PM Reply With Quote
Got one in the workshop at the moment with a leaking (custom?) ally rad. The mountings on the chassis look spaced to fit the smaller rad from the 1lt Polo thats used on lots of 7's.
Vertical distance between mounts is right but I don't know the width as mine has the wider 1.3 rad so can't compare.
http://jpsc.org.uk/forum/
