clutch_kick
posted on 14/4/06 at 11:09 PM |
What bits do I need?
I started picking a few bits and peices here and there, preparing my stockpile of bits before i order the kit. I've finally settled for the
Busa engine option, and i want to use the Bike's clocks too.
So out of the bike i need what .. Engine (duh!?!), Loom and ECU. I suppose i need the Sub-loom to get the clocks wired up too.
Fuel pump ... I found out the busa unit is a cute little peice of kit, with an built im fuel level sender, that hooks up to the gauge on the
bike's cluster. Can i get that pump fitted in the MNR tank?
As for the Diff ... will a diff out of a Sierra diesel do the job? 3.16 i think.
chockymonster
posted on 15/4/06 at 01:56 AM |
For the busa you either want a 3.38 or a 3.14. I'd aim for the 3.14 if you can find one as they are a rare beasty
JoaoCaldeira
posted on 15/4/06 at 06:30 AM |
Will you order the donnor stuff from MNR?
What kit will you order? Different kits have different parts included.
Joao
clutch_kick
posted on 15/4/06 at 09:33 AM |
HI Joao ... i'm trying to get a few bits locally, and down to work refurbishing them. To keep me busy until i get down to ordering the kit.
It will definately be an RT, poly bushes are nicer on crap maltese roads.
Still trying to figure out which sierra models had the longer diff that i need for the Busa. What about the freelander?
JoaoCaldeira
posted on 15/4/06 at 10:11 AM |
Hi.
Probably a few more than this, but that's what I remember:
Diff, half shafts, handbrake, rear brake assembly, steering column - needs modification; possibly central mirror too.
I'm using a drum donnor with MNR adaptor plate to use discs, as its lighter than the discs version.
Your favorite donnor might be the 2.3 Diesel...
Here is some info I've gathered (probably right, but not sure)
Diffs
. Size
Sierra 1.6, 1.8, 2.0 have a standard 7” diff
Sierra XRi and XR4x4i have a 7” LSD
Sierra Cosworth 2wd and 4wd have a 7.5” LSD
. Ratio
1.8 TD 3.38
2.3 D 3.14
Brakes
. Rear Discs
XR4i [Later > 83]
XR4x4i
All 7.5" Diffs
Ford axle codes (on the VIN plate)
A=3.36 B=3.77 D=3.92 F=3.842 J=4.056 K=3.31 M=3.14 N=4.29 P=3.58 J=3.62
V=3.33 Z=3.59 2=4.27 3=3.62 4=3.82 5=3.26 6=3.12 8=3.56
3,14 CW47-Pin15
3,38 CW44-Pin13
3,62 CW47-Pin13
3,92 CW51-Pin13
3,77 CW49-Pin13 6.5 inch diff
3,38 fitted to 1,6 OHC ECO 5 speed
3,38 fitted to 2,0 OHC HC
3,38 fitted to 2.3 v6 ESTATE
3,14 fitted to 1,6 OHC ECO 4 speed
3,14 fitted to 2.3 v6 SALOON
3.14 fitted to 2.3 Diesel
85GG 4006 DC --- 3.97
85GG 4006 BC --- 3.62
85GG 4006 AC --- 3.38
85GG 4006 FB --- 3.36
87BG 4006 GB --- 3.14
86GG 4006 AAA --- 3.92 LSD
V87BB 4006 BAA --- 3.62 LSD
V87BG 4006 CAA --- 3.38 LSD
85GG 4006 AAA --- 3.36 LSD
Vin plate codes for Diff ratio
Ratio Code
3.14 M
3.36 A
3.38 U
3.62 V
3.64 3
3.92 D
clutch_kick
posted on 15/4/06 at 10:26 AM |
Joao ... thanks a lot my friend.
chockymonster
posted on 15/4/06 at 10:48 AM |
The 1.8td doesn't always have the 3.38
It works as a guide but the 2.3 diesel will have either the 3.38 or the 3.14
My 3.38 came from a 2.3 diesel. My 3.14 came from a 2.0l estate!
JoaoCaldeira
posted on 15/4/06 at 01:02 PM |
Forgot to mention that the later models seem to be assembled of whatever was left in the assembly plant, so the list is not to be trusted
blindly...
Joao
