Author: Subject: MNR Pedal Box - Alignment
Krismc
posted on 16/4/06 at 06:04 PM Reply With Quote
Right i finally got the chance to remove the tub, fit and fit the clutch pedal!
Thing is the clutch and brake pedal dont sit the same distance from the foot well back wall - is this correct??,
If so which pedal should i line my accelerator up with!
If not then I think the brake pedal sticks out too way far but the only way to move it back is to cut the Cylinders threaded rods!
pic below
[Edited on 16/4/06 by Krismc]
DIY Si
posted on 16/4/06 at 06:25 PM Reply With Quote
Not sure about how they're supposed to be, but personally I'd prefer the brake pedal to stick forward most as it's the pedal you'll want to hit first in an emergency! Don't want to be aiming for the brakes and boot the go pedal instead.
Winston Todge
posted on 16/4/06 at 06:33 PM Reply With Quote
Mine is similar bud, but by screwing in the master cylinders more you can pull the pedal back a bit.
I am currently looking at the throttle pedal positioning but without brake pressure, you can't really tell where you want to line the throttle pedal up for best heel and toe placement.
I think I may wait until I have the rolling chassis built up and bled brakes. Then I suppose it'll be easier to work this out?
Krismc
posted on 16/4/06 at 07:02 PM Reply With Quote
The master cylinders can be screwed in further can they??
I suppose ill have to wait too, but with out the pedals finished i cant put the scuttle and with out the scuttle i cant do battery or wiring! id rather Know roughly how they are supposed to fit!?
Agriv8
posted on 16/4/06 at 07:19 PM Reply With Quote
Mine are all level but the 38 inside leg and the size 13's, means that I need all the space i can get after ensuring i had enough travel to activate front and rear braking systems fully.
Then re aligned my pedals which meant removing some of the tread bar on the master cylender push rods ( about 5 to 10mm possibly a bit more as i removed it in several attempts ) if you do this pop a nut on before cutting so when you wind the nut off it will clean the threads up.
regards
Agriv8
Krismc
posted on 16/4/06 at 07:32 PM Reply With Quote
regards
cheers, thats what i wanted to do, but was scare to, so just wanted to make sure i had enough travel in the pedals to do so!
and to get this clear......
.. your clutch, brake and acc, stand at 90 degrees to the floor and are approx inline with where my clutch pedal is in the picture??
Winston Todge
posted on 16/4/06 at 09:47 PM Reply With Quote
Sounds like a good solution but by the looks of the picture you'd have to cut off a fair bit to make all the pedals level?
Any chance Marc has a take on this Ian?
My pedals will probably sit with the brake a little forward from the other two. Any problems with that?
Agriv8
posted on 16/4/06 at 10:00 PM Reply With Quote
A couple of pictures just uploaded to my archive. a little large but too piddled to start editing at this time of night ( ps no coments on the state of the garage as i have been gardening and visiting mother in law all BH).
Hard to tell from the photo's but clutch and accelerator probably 85 deg brake at 80 deg.
Ps i am running my accelerator at an angle following the angle of the interiaor pannel for foot space.
Sure marc will pass coment but I think he is having tomorow off by order of Mrs MNR.
Regards
Agriv8
scoey m
Builder
Posts 209
Registered 8/2/06
Member Is Offline
Photo Archive Go!
Building: MNR Vortx r1(sva pass 07 plate yumyum)
posted on 16/4/06 at 10:01 PM Reply With Quote
i was going to post same question tonight
there is quite a lot of thread on slave cylinders spare to make pedals more level if its not possible to do it like this my knee will be very sore from bouncing of steering wheel every time i wanted to brake
Winston Todge
posted on 16/4/06 at 10:27 PM Reply With Quote
Ta for that Ian. Much appreciated.
How much did you pay for the Super Quadro? I'm going to get that wheel... Looks so good and more leg space!
Chris.
Winston Todge
posted on 16/4/06 at 10:30 PM Reply With Quote
P.S. What do you use the push buttons for on the wheel Ian? Indicators?
Chris.
JoaoCaldeira
posted on 17/4/06 at 09:06 AM Reply With Quote
Agriv8:
Is your left MC for rears?
Thanks,
Joao
Krismc
posted on 17/4/06 at 09:20 AM Reply With Quote
yea ill wait to see what Marc reccomends! before i start hacking away!
Mix
posted on 17/4/06 at 10:15 AM Reply With Quote
An alternative to shortening the master cylinder push rods is to fit spacers/washers between the bulkhead and the master cylinders.
Mick
Krismc
posted on 17/4/06 at 10:46 AM Reply With Quote
the ali bulk head and the pedal box are ressesed and fit snugly so i dont want to do that!
Agriv8
posted on 17/4/06 at 08:08 PM Reply With Quote
sorry for the delay chaps been hacking a hole in spare bedroom ceilling and fitting loft ladders all day .
left MC is front but brakes not fully bedded in jet ( cant get enoungh heat in the fronts to heat cycle them !! ). so dont referance bias bar settings
The steering wheel was bought as a package with quick release boss from MNR not sure of a price ( chris N will know ) ps if you go down the route your colum will have to come out to enable the shaft part to be tigged on ( marc did mine we trned down a peice of bar to fit in the center ).
RE The two buttons - one is horn ( post sva as it went to SVA with the sierra item on for horn and stering lock ).
The other is for the NOZ ( i wish - aint got the money at the moment ) likley to plumb the other button to high beam flash. both buttons are conect by a quick relaese connector for when the steering wheel is released.
regards Agriv8
G.Man
posted on 18/4/06 at 07:57 AM Reply With Quote
Nice steering wheel iain...
Looks familiar
Opinions are like backsides..
