Author: Subject: Fuel pump: connect to to car loom or to bike loom
JoaoCaldeira
posted on 22/5/06 at 08:07 AM Reply With Quote
Hi Marc.
In a fuel injected R1 (2003 in my case) what have you done to connect the fuel pump (Bosch high pressure):
. directly to the bike loom (ECU drives it)
. to the car loom but through a relay commanded by the bike loom (due to amp constraints)
. permanently to the car loom
Thanks,
Joao
tks
posted on 22/5/06 at 08:50 AM Reply With Quote
Deffenitly
you need to connect it to the R1 loom!!!
dunno if they check it!
but its the only way of making the system secure.
When you put the loom on contact the pump wil run for 10seconds.
after that it will only run if the engine makes rpm.
in case of a accident and the engine stalls, the fuel will be cut of.
This is obligiatori in all injection cars.
On my honda loom the fuel pump relais gets it signal from the mcu.
and the relais powers the pump.
Regards,
Tks
G.Man
posted on 22/5/06 at 09:52 AM Reply With Quote
It must be connected to the bike loom (via the Bikes fuel pump relay), or you will not be able to achieve a stable fuel pressure and the fueling will be all over the place...
Marc will back me up on this when he reads this without a doubt!
[Edited on 22/5/06 by G.Man]
Opinions are like backsides..
Agriv8
posted on 22/5/06 at 10:07 AM Reply With Quote
Yup,
Will second that Mark that took some finding
how the car going ?
regards
Agriv8
G.Man
posted on 22/5/06 at 10:43 AM Reply With Quote
Car is going sweet, except for an annoying oil leak I cant trace...
Hows yours?
amalyos
posted on 22/5/06 at 10:51 AM Reply With Quote
Do you need to do this with the Carb Version?
I've connected mine to the MNR loom (but not yet started the engine yet).
Agriv8
posted on 22/5/06 at 11:19 AM Reply With Quote
Hows yours?
Excellent need a rolling road session to get her tunned - 500 miles done.
RE oil leak I have one of those its called a Rover V8 engine I am down to the odd drop but Ill be buggered if i can find it. Might have to resort to the talculm powder
Regards
AGriv8
chockymonster
posted on 22/5/06 at 03:14 PM Reply With Quote
Back on the subject of fuel pumps, what's the advised one to use for an R1? The standard bike one looks a bit open to the elements.
JoaoCaldeira
posted on 22/5/06 at 03:46 PM Reply With Quote
IIRC that will depend on which R1.
For carbed ones, the one from the bike.
For injected, unless you have put the original pump inside the tank (you would have butched the tank, then) you will need one good for 3 bar. Now and then there is one on eBay. Bosch seems the most used.
Joao
chockymonster
posted on 22/5/06 at 04:57 PM Reply With Quote
I'm using a 2003 5PW.
Do you happen to have the part number for the one you've used?
Joao
JoaoCaldeira
posted on 22/5/06 at 08:39 PM Reply With Quote
Got it on the laptop.
I'll post tomorrow.
Joao
PS: My bike is not running yet, so don't trust it blindly (although I'm confident )
RichieC
posted on 22/5/06 at 10:41 PM Reply With Quote
Hi mate, just beware the fuel pump feed from the MNR loom is a permanent 12v with the ign on. It needs the 12v supplied only to prime up the carbs and then when the pressure drops while running, this is done by the fuel pump relay. Its a black/blue on the R1 loom.
Rgds
Rich
marc n
posted on 23/5/06 at 07:45 AM Reply With Quote
yep fuel pump must run through the relay on the fuel injected models otherwise the ecu goes to limp home mode
been there and done that
from memory we used the original bike relay spiced into the mnr loom, removeing the original feed
[Edited on 23/5/06 by marc n]
please email rather than u2u
chrismnrltd@btinternet.com
G.Man
posted on 23/5/06 at 07:51 AM Reply With Quote
Aww be fair marc, we did have a lot of fun trying to solve it...
LMAO
marc n
posted on 23/5/06 at 07:52 AM Reply With Quote
amalyos
posted on 24/5/06 at 05:36 PM Reply With Quote
Still confused
Can I use the MNR loom fuel pump feed for my R1 with CARBS (5JJ)?
Or do I need to connect the R1 loom pump feed?
Help !!!
marc n
posted on 24/5/06 at 05:40 PM Reply With Quote
hi steve you use the mnr loom
p.s parcel left today
RichieC
posted on 24/5/06 at 05:43 PM Reply With Quote
Hi all,
Not wanting to put a spanner in the works, but the MNR fuel pump feed is perm 12v with the ignition on.
The 12v from the bike loom is switched by the puel pump relay. Is it the pump which controls its feed pressure or the fuel pump relay?
The only real difference I can see is the relay outputs 12v with ignition then continuously when cranking and running.
marc n
posted on 24/5/06 at 05:49 PM Reply With Quote
the pumps i have fitted have been same as a facet type pump constantly supplied with 12v
best regards
marc
RichieC
posted on 24/5/06 at 06:07 PM Reply With Quote
Ah righty, yeh constant delivery in otherwords. Did you use a filterking reg with them?
I think, bike pumps have a sort of idler and are not constant delivery. Ill know better when I fit the new pump but I expect if it was connected to a perm 12v feed would flood the carbs if there was no way of shutting off when the floats were full. This of course could be controlled directly by the bike pump as I cant see how the relay would know the float bowls were full.
Hope that makes sense!
Rgds
Richie
smart51
posted on 24/5/06 at 08:44 PM Reply With Quote
My R1 pump is fitted to the MNR loom and is on with the ignition. The pump clicks rapidly at first (if the car has been off for a few days) then slows down and stops. Once it is up to pressure like this then it stays stopped, although once the engine is running, you can't hear the pump.
I've done almost 3000 miles in 6 months and it's OK so far.
RichieC
posted on 24/5/06 at 09:19 PM Reply With Quote
Yeh that backs up the theory that its the pump which controls the pressure ie as soon as x amount of pressure is felt in the line to the float bowls, the pump slows and stops until its needed again.
Rich
amalyos
posted on 25/5/06 at 06:55 AM Reply With Quote
Cheers Marc.
Steve.
JoaoCaldeira
posted on 25/5/06 at 07:24 AM Reply With Quote
Although we are all speaking about the R1, "re 2002" and "2002 on" work very differently. Actually the pre 2002 has a fuel pump relay that the 2002 on doesn't have.
Even so it seems that would be wise to connect the bike loom fuel pump connector to a relay controling the permanently on of the MNR car loom.
Joao
