Author: Subject: MNR suspension
bassett
posted on 11/5/08 at 02:36 PM Reply With Quote
MNR suspension
Hi, just wanted to know others expieriences with susp bushes. My dads trial fitting them at the the moment to make some templates for the bodywork so hes fitting the bushes to get it all assembled. Should the bushes sit completly flush as he has one side that isnt flat to the wishbone all they way round. Also should any of the tubes between the bushes be trimmed or should they go straight in?
thanks
vinny1275
posted on 11/5/08 at 05:42 PM Reply With Quote
Hiya,
Ours were quite tight - in fact, one bone didn't reall fit at all. This is because they hange the chassis from the pickups to wekd it, and there's some movement on there to allow for the chassis to heat up, so ours were the maximum distance out (about 2 - 3mm all in). I spoke to Marc, and he said if they're tight to jut persuade the pickups open slightly and they'll close up on the bones when you tighten them up. our bushes also didn't go flush on both sides without tightening the bolts...
HTH
Vince
bassett
posted on 13/5/08 at 06:44 PM Reply With Quote
Cheers Vince il get him to do that.
Adam
