<<  1    2  >>
Author: Subject: 5jj R1 electrical help needed!
GeorgeM
posted on 20/5/09 at 10:04 PM Reply With Quote
Dan, not suggesting a permanent solution,
but at least we will know where the problem is!
just use a length of wire with an in line fuse
to test it
GeorgeM
[Edited on 20-5-09 by GeorgeM]
daniel mason
posted on 20/5/09 at 10:07 PM Reply With Quote
thanks george. your help today and yesterday is very much appreciated. if i catch you at a show i will buy you a beer.but only if your correct! lol.
GeorgeM
posted on 20/5/09 at 10:09 PM Reply With Quote
I'm still intrigued about this loose wire.
You say it puts the savage lights on
when you touch it to where??
GeorgeM
daniel mason
posted on 20/5/09 at 10:12 PM Reply With Quote
if i remove ignition key barrel and connect to spare terminal.it lights up switches when key is turned
GeorgeM
posted on 20/5/09 at 10:20 PM Reply With Quote
so when you put 12v on it through the
ignition it lilluminates the savage bulbs?
Sounds like it has been added to give
illumination for the 2nd speedo then.
I would tape it up for now so it can't touch
anything, then once everything is working
you can remove it if you wish. Can you
see where the other end of the wire is?
GeorgeM
daniel mason
posted on 20/5/09 at 10:23 PM Reply With Quote
i was told it was illumination and it is just twsted and taped on to a cable which goes into a conector block.
TimC
posted on 21/5/09 at 07:26 AM Reply With Quote
Ok - if its a connector block, its not from my loom. Having said that, I'm not sure where MNR took the live from for the lighting loom.
Ah-ha.... check each of the blade connections on the FIA master switch.. one of them goes to the coils!!!
<<  1    2  >>
