paublo999
| posted on 30/4/11 at 06:20 PM |
Mnr do replacement steel uprights that may be more appropriate. You can retain the same hubs etc?
My videos http://www.youtube.com/user/ninjabogeyracing
daniel mason
| posted on 30/4/11 at 06:30 PM |
i have the steel ones. i will try to dig uot a pic for you
Krismc
| posted on 30/4/11 at 06:38 PM |
There's some in for sale section, or mnr can supply parts, and in exploded diagram it shows hub/stub and bearing, spacer, compression and then
bolt but its actually hub/stub and bearing, compression washer and then spacer with bolt though. Ill send you a pic via email with my finger pointing
to it.
[Edited on 30/4/11 by Krismc]
johnny chimpo
| posted on 30/4/11 at 06:39 PM |
Cheers guys....
Just popped out to the garage and took a couple of better pics of the upright and the damage to the stub axle....
Pic 1
Pic 2
Pic 3
Cheers for the info Paul, hopefully MNR can sort me out with the bits I need. Hows the sprinting getting on, Im hoping to come along to a few events
this year. Still got big Stephen helping you? (I know him from SIDC, think I actually met you at one of the SIDC track days aswell).
Thanks Daniel, if you could get a pic that would be much appreciated.....
The whole kit car thing is new to me.... just hope I can get mine back on the road asap and get enjoying it before the sun goes away again!
johnny chimpo
| posted on 30/4/11 at 06:41 PM |
quote: Originally posted by Krismc
There's some in for sale section, or mnr can supply parts, and in exploded diagram it shows hub and bearing, spacer, compression and then bolt
but its actually hub and bearing, compression washer and then spacer with bolt though. Ill send you a pic via email with my finger pointing to it.
Cheers Krismc, I cant seem to view the thread in the for sale section with them.... says I need to be a contributor?
Any idea where I could get an exploded diagram of how it should all be?
Cheers again guys.... all this help really is much appreciated!
Krismc
| posted on 30/4/11 at 06:47 PM |
Yea, send him a u2u and ask for details,
i cant find the exploded diagram but heres a half exploded picture.
Ive just worked out why mine are a differant colour, yours are sierra like these and mine are cortina raceleda
Krismc
| posted on 30/4/11 at 06:50 PM |
You may have missed the bandwagon, first ones sold
johnny chimpo
| posted on 30/4/11 at 06:52 PM |
Whats the name of the user selling them.... as I can see the thread in the forsale section, but it wont even show me who has posted it up because it
is less than 48hours old and I need to be a contributor, I think its to do with the number of posts ive made on the forum?
johnny chimpo
| posted on 30/4/11 at 06:55 PM |
Doh! looks like im not quick enough! Hopefully a phone call to MNR will sort me out... just hope its not mega expensive as I spent almost all my money
for just now buying it and insuring it....
daniel mason
| posted on 30/4/11 at 08:10 PM |
they will not be sierra surely? mnr have been on modded cortina for years now!
Krismc
| posted on 30/4/11 at 08:51 PM |
Well I've seen a few rts with sierra uprights.
daniel mason
| posted on 30/4/11 at 09:01 PM |
yeah but not a 2009 car surely? i thought sierra geometry went years ago on the mnr?
Krismc
| posted on 1/5/11 at 06:52 AM |
Im not sure when actually, thought the RTs had sierra til at least 2008 not sure when they phased them out.
daniel mason
| posted on 1/5/11 at 09:51 AM |
has the stub axle bolt snapped causing the prolem as the upright seems in tact. unless its bent. the originals were snapping! that wheel is seriously
out of line so it could have bent the wheel studs or the stub axle
johnny chimpo
| posted on 2/5/11 at 09:01 AM |
Been sitting thinking a lot about this since it happened.
I think what has happened is that the stub axle bolt has been loose and has allowed the stub axle to move and wear away the internal of the upright.
The wheel has probably been sitting at a bit of an angle before i got the car (and i didnt notice it when initially viewing it). The 200 mile drive
home has basically just killed the internal of the upright and the hub, eventually putting enough strain on the calliper to snap its mounting bracket.
Just hope mnr can sort me out with the parts to fix that side.
Im goin out now to my garage to strip down the drivers side and check its all ok.
daniel mason
| posted on 2/5/11 at 09:16 AM |
check the stub axle bolt on the drivers side as well as the hub nut.
you will possibly need a pair of steel uprights, a new hub and bearings.
johnny chimpo
| posted on 2/5/11 at 04:43 PM |
Cheers Daniel, stripped down the drivers side an everything is fine, looks like just the passenger side needs replacing.
Im gona do a full nut and bolt check on it over the next few days to hopefully prevent any future mishaps similar to what has happened so far.
Will post up again once I am further on with resolving...
daniel mason
| posted on 2/5/11 at 06:19 PM |
was unsure if they still do the alloy version as the steel ones they do are both lighter and stronger. they also have wingstay brackets pre welded.
