designer
| posted on 6/6/11 at 03:48 PM |
Well, that's your application to be a structural engineer refused, especially if you think force reacts in a curve and bending moments
don't count!
v8kid
| posted on 7/6/11 at 07:46 AM |
don't count!
Too late My background is as a professional engineer and a design manager of a multidisciplinary design office employing another 6 professional
engineers.
You know you should really read and attempt to understand posts before you reply. Your response was rubbish because you ignored the additional points
raised and merely restated your opinion without attempting to justify that opinion. It had already been demonstrated why that opinion was faulty and
you chore to ignore this -that was rubbish.
To restate the blindingly obvious all designs have to be fit for purpose and untill you define that purpose you cannot attempt a design. Despite it
being poined out to you that there were specific manufacturing, use and marketing considerations you chose to ignore them and simply restate a
simplistic opinion.
Do I have to say it a third time?
Absolute rubbish
Cheers!
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a
chainsaw
designer
| posted on 7/6/11 at 09:31 AM |
And my 'inept' designs rotate at 200,000 revs, fly at Mach 2, are used on Formula cars and at SERN, and one is wending it's way to
Venus!
This is a forum for the layman.
'Fit for purpose' is the cheap route and many parts work, no matter how badly they are designed; a part made from old bed ironwork will
function just as well as a suspension component. If you mount a jet engine onto a barn door and send it down a runway, it will take off, is it still a
plane?
Just in the same way that CAD does not make a bad engineer good.
Strontium Dog
| posted on 7/6/11 at 11:22 AM |
Now now, this is getting personal and isn't going to help anyone. An open and friendly discussion is more likely to be of help to everyone!
Now IMHO, Designer has a valid point about how forces act and how it is best to avoid bending moments around weld areas. However, this is out the
window to a degree as soon as you build a wishbone with adjustment at the outer end (top ball joint) because the very adjustment will alter the line
of force. Adjustment on the inboard end will mean a dogleg and again the line of force will not run exactly along the tube.
It can thus be seen that a compromise must be entered into if the bone is to be adjustable. If the jigging of the suspension brackets is spot on (rare
indeed) then a non adjustable arm with perfect force alignment would be possible, but with no scope for any adjustment except by substituting other
bones with differing geometries, possibly the best solution engineering wise but a PITA to implement!
That's how I see it anyway. I guess the question should be, has there been any failures of the MNR wishbones or are they fit for purpose. I
guess they are or there would be a lot of crashed MNR's and some seriously disgruntled owners. The rest is down to aesthetics and what you
personally think looks good!
mcerd1
| posted on 7/6/11 at 11:57 AM |
not to mention off topic....
no designs are perfect, there is always some kind of compromise
the MNR ones work - plenty of cars on the road without issues to prove that (and thats the best kind of proof IMHO as a structural engineer)
but I'd strongly suggest that any further debate on this subject is in a new thread - incase jlayton or any other new owners/builders are
sacred off by all this
[Edited on 7/6/2011 by mcerd1]
v8kid
| posted on 7/6/11 at 12:22 PM |
Very true mcerd1 and Strontium Dog point taken but it's fun
Should we have an "Insult each other" or "Handbags at dawn" forum - it might catch on?
Cheers!
chainsaw
Hector.Brocklebank
| posted on 24/7/11 at 03:25 PM |
Cheers!
Sounds like a plan... I vote we install "Calvinx" as head moderator on any such site !!!!!
