Author: Subject: Vortx prop / general prop query
Pdlewis
posted on 23/11/08 at 06:46 PM Reply With Quote
Im going to get my prop adjusted this week I have a sierra 2 part job Im thinking i need to get the following done. This is for a Vortx with a R1 5pw in it
1. recon the UJs
2. New centre bearing
3. Have the short section lengthened (sliding joint) by 10"
4. Have a UJ and new flange (for sproket adaptor) added to the short section
Does this sound about right?
I know i should have a TRT but money is a bit tight and I need to get SVA'd before the IVA comes in and plan to replace with a TRT in the summer or next winter
Build Photo Album
Updated 05/02/2009
TimC
posted on 23/11/08 at 06:55 PM Reply With Quote
Sounds fine.
TC
Guinness
posted on 23/11/08 at 07:13 PM Reply With Quote
I left the original UJ and centre bearing in, and 4,000 miles later I haven't had any issues from it. (touches wood)
By the time you've replaced the UJ, centre bearing, shortened it etc, would it not be cheaper / easier to buy a new bespoke prop from MNR? AFAIK they are £195?
Mike
stuart_g
posted on 23/11/08 at 08:32 PM Reply With Quote
If I were you I would have the prop made TRT now. You will have to split the prop at the centre bearing to get it in if you have already fitted the engine and this can be very difficult. It will be even worse trying to split it to remove it to be modded again while in the car.
I think it will be false economy to have the sierra one you have modded now and then have it converted to TRT later. Cost vurses hassle, cost would win IMHO.
