jambo
| posted on 26/11/08 at 10:03 PM |
mnr balance bar
hi
the cylinder pushrod clevis's either side of the brake pedal,do they have to be tuching the pedal so it cant move from side to side without
screwing the balance bar.
a picture of one ready for sva would be great.
thanks.
[Edited on 26/11/08 by jambo]
adithorp
| posted on 26/11/08 at 10:46 PM |
There should be a slight gap. As you press the pedal the angle of the bar changes. Without the gap the clevices would bind against the pedal tube.
Have a look at the Rally Design site for setup guide.
http://www.rallydesign.co.uk/balancebar.php
adrian
http://jpsc.org.uk/forum/
stuart_g
| posted on 26/11/08 at 10:49 PM |
Here is mine after SVA. I put a thin washer between pedal and clevis. Pic also shows roll pins in lock nuts.
jambo
| posted on 26/11/08 at 11:17 PM |
ok so how do i get the clevices closer together with the master cylinders fitted,
does the pushrods screw off or do you have to spin the masters?
smac
| posted on 26/11/08 at 11:29 PM |
the pushrods should screw out of the clevis'
adithorp
| posted on 27/11/08 at 08:37 AM |
Your clevis' have to be in line with the mastercylinders otherwise you'll get sideways forces on the pistons. Take up the gap with
spacers/washers and keep the pushrods parallel.
adrian
