jambo
| posted on 3/12/08 at 10:58 PM |
front upright on mnr
just want to check this before i rivet up the bodytub.
how plumb(in line) should the two rod eyes be on the top and bottom bones.
the bottom bones are not handed but the top are.
i have tried the top bone on what i think is the right way but the eyes are 25mm out of line,so tried other side the other way and they are more in
line but 15mm the other way out of line.
[Edited on 3/12/08 by jambo]
jambo
| posted on 3/12/08 at 10:59 PM |
2nd pic of other side with top one on what i believe the wrong way,although nearer inline just 15mm out.
tootall
| posted on 3/12/08 at 11:02 PM |
on the mk they use sierra up rights and they are set back 25 mm to give right KPI of about 5 deg so would think your fist pic is wright
some people dream of sucsess, others just get on and do it !!
maximill666
| posted on 3/12/08 at 11:20 PM |
Correct way shown in the first pic
Regards,
Lee.
MikeR
| posted on 3/12/08 at 11:44 PM |
Top wishbone should be closer to the rear of the car - this makes the steering do all sorts of nice things. Which ever way gives you the most offset
(ie closest to rear of car) is right.
GeorgeM
| posted on 4/12/08 at 12:30 AM |
think you will find lower bone is upside down
Gergely
| posted on 4/12/08 at 05:52 AM |
The top ones are fine, the lower ones should be swapped left to right I believe. We had exactly the same thing. Put the lower wishbones on so that the
circlip is on the bottom and the pushroud mount as well (correct on your pic) and make sure that the pushrod itself is as straight when compared to
the pivot linkage as possible. This will probably mean in your case that you need a left-right swap.
Gergely
Our build pictures
marc n
| posted on 4/12/08 at 06:49 AM |
hi jamie
first pic is correct
best regards
marc
please email rather than u2u
chrismnrltd@btinternet.com
