Author: Subject: fitting studs to hubs
jambo
posted on 4/12/08 at 09:33 PM Reply With Quote
on the supplied mnr stuff,whats the best way to get the wheel studs into the ally bearing carriers.
thanks.
Johneturbo
posted on 4/12/08 at 09:37 PM Reply With Quote
A press would be ideal
or you can pull them through with a nut and loads of washers
austin man
posted on 4/12/08 at 09:41 PM Reply With Quote
and if you ant got enough washers use a 1/2" drive socket
posted on 5/12/08 at 08:10 AM Reply With Quote
yep - pull through by doing the nut up.
I did this but frist go was to press unsing a vice but they didn't go in square - I was lucky enough to be able to getthe wheel on; doing it up squared them up.
John Bonnett
posted on 5/12/08 at 01:18 PM Reply With Quote
It sounds brutal but they can be hammered in quite satisfactorily by laying the hub face on your vice opened just sufficiently and hammering the studs in from the back with a Club hammer. This is how I have always done it and checking with a mechanic friend he confirmed that is the way they do it in the trade.
John
bassett
posted on 5/12/08 at 01:53 PM Reply With Quote
Hi, when doing ours the nut and bolt method i wasnt happy - chewed up the nut thread and washers got a bit mangled. I think in the end it was done with a hydraulic press most local garages would have them then you get them bang on square.
