sucksqueezebangblow
posted on 5/12/08 at 02:20 PM |
What is maximum amps for MNR horn circuit?
Hi All,
Does anyone know what the maximum ampage the horn circuit can handle on an MNR supplied loom?
I'm thinking of fitting the Nautilus air horn but it draws 18 amps.
Mr Whippy
posted on 5/12/08 at 02:21 PM |
what I just typed in your other post...
Originally posted by sucksqueezebangblow
Hi All,
Thanks for all the recommendations. I've just taken a look at the Nautilus and the Magnum.
I've gone for the Magnum based on weight and ampage, but might yet go for the Nautilus if the MNR wiring will take it (and put the Magnum on the
Buell instead).
you could have simply ran a single 20amp wire from the battery, though a relay switch triggered by the original horn feed.
That’s what I'm going to do for my cbr125
[Edited on 5/12/08 by Mr Whippy]
