dave107
posted on 10/12/08 at 08:48 PM |
Propshaft install
Help.
I have installed my short propshaft to the engine and Quaife box.
Can someone tell me how to install my rear propshaft to the Quaife box as the flange on the end of the propshaft does not fit in the tunnel.
jimgiblett
posted on 10/12/08 at 08:58 PM |
Nice to hear from someone local.
Have you panelled the tunnel?
Or perhaps remove the Quaife box fit the rear prop and then refit the box perhaps.
Photos?
- Jim
Johneturbo
posted on 10/12/08 at 09:03 PM |
Do you mean the flange that bolts to the diff? if so can't you fit it from the rear? oh-er
GeorgeM
posted on 10/12/08 at 09:05 PM |
IIRC, slide in from back before fitting diff
Howlor
posted on 10/12/08 at 09:06 PM |
You can split the joint and reassemble once in place. That is what I did.
dave107
posted on 10/12/08 at 10:50 PM |
Propshaft install
Propshaft has to go in from the back due to flange diameter on back of prop.
Tunnel is not closed off.
Flange on the front of the prop is 87mm diam, flange on diff end of prop 110mm diam, width in tunnel 77mm.
I have been fitting from the back and diff is out.
Steve can you explain how you split the joint please.
Oh-er Johneturbo i have tried to fit from the rear without the diff in that's the only direction it will go in from.
Agriv8
posted on 11/12/08 at 08:20 AM |
If you split your prop put tipex marks so you can re-assemble it back together in the same orientation.
regards
Agriv8
dave107
posted on 11/12/08 at 10:03 AM |
Propshaft install
Thanks for replies.
New day fresh mind.
Understand now were you split prop quite easy really.
Howlor
posted on 11/12/08 at 08:11 PM |
Good o
