Author: Subject: Torque setting on front cortina uprights
bassett
posted on 10/1/09 at 06:50 PM Reply With Quote
Hi, wondered what torque setting others are doing there front hub nuts upto with allumium hubs?
Adam
stuart_g
posted on 10/1/09 at 08:01 PM Reply With Quote
I didn't torque mine up. I tightened it with a ratchet untill there was resistence in turning the hub, then loosened the nut and re-tightened the nut lightly, made sure there was no free play and the hub turned with no resistance.
No problems so far and no play anywhere.
I don't think they need to be torqued up just tightened enough so there is no play in the hub.
mark chandler
posted on 10/1/09 at 10:30 PM Reply With Quote
Same as above, wound them up until the hub starts to bind, back off 1/3rd turn, job done.
Cousin Cleotis
posted on 11/1/09 at 10:18 AM Reply With Quote
with the wheel on and brake pads clear of the disc tighten the nut until there is the smallest amout of play possible when rocking the whel top and bottom.
More people would see this question if it was in the suspension forum.
Paul
bassett
posted on 11/1/09 at 11:10 AM Reply With Quote
Cheers everyone so no torque just tight so it still spins which is probably what its at, at the moment but wanted to check
Adam
Cousin Cleotis
posted on 11/1/09 at 02:19 PM Reply With Quote
That sounds way too tight, there should be NO preload.
If you dont beleive me repost this in the main forum, you will stand more of a chance at getting the correct information.
Paul
Johneturbo
posted on 11/1/09 at 08:55 PM Reply With Quote
Like has been said, you just want it so there isn't any excess movement of the wheel
