Author: Subject: Track rod ends
dave107
posted on 21/1/09 at 09:22 PM Reply With Quote
Track rod ends
i am about to fit my steering arm track rod ends and raceleda uprights, i thought the track rod ends go above their fixing point with the bolt going down through the fixing hole and secured from below, but i have seen two cars with the track rod ends secured one from below and one from above both using the same setup as mine.
Any thoughts please
posted on 21/1/09 at 09:40 PM Reply With Quote
Which ever way keeps the steering arms level I suppose.
Looking at a one (MNR) the other night they were underneath with the bolt on top.
bassett
posted on 21/1/09 at 11:21 PM Reply With Quote
Mine are below with Nut on top which im almost certain is correct. My uprights should only go one way round as they are the mnr fabricated ones not the raceleda so im not sure if that makes a difference - best thing to do is send Marc a picture and ask if its correct.
Sorry said bolt meant nut now edited
[Edited on 22/1/09 by bassett]
jambo
posted on 21/1/09 at 11:26 PM Reply With Quote
bolt to top,also curving out to front of car
sorry i mean nut to the top(edit)
[Edited on 22/1/09 by jambo]
Gergely
posted on 22/1/09 at 08:16 AM Reply With Quote
Ours are bolts from below, with the nyloc on top. But check with Marc, that is always the best.
Our build pictures
sucksqueezebangblow
posted on 22/1/09 at 09:47 AM Reply With Quote
I checked with Marc when I did mine. Nut should be on top and arm should curve forward to the steering arm.
dave107
posted on 22/1/09 at 10:12 AM Reply With Quote
Thanks guys i will talk to Marc and get his advise.
jambo
posted on 22/1/09 at 11:14 PM Reply With Quote
sorry i always mix up my nuts and bolts
nut to the top.
