Krismc
| posted on 6/2/09 at 08:18 PM |
MNR loom & Fog light switch
Does any one know what colours are what at the fog switch??
Ive a 2006 Chassis No 40 vortx, fog lights have never worked, and im busy fitting savage switches to the car.
Replaced the fan switch and that works fine but the fog is blowing fuses.
Red/yellow and a black at the fog light. and black, red/yellow, red/yellow and another colour (which ive forgot) at the switch.
.....oh and im a electrician(apparently), but without knowing what is what it may take a while to trace out, so i thought id ask first.
tomgregory2000
| posted on 6/2/09 at 08:35 PM |
i dont know if this will help you as i only have 3 wires to my fog switch but i had o problem of blowing fuses and worked out that it was all to do
with my red and red/yellow wires were round the wrong way and shorting out down the earth wire for the telltail light on the switch and so swapping
the red and red/yellow wires round sorted the problem.
Tommy
bassett
| posted on 7/2/09 at 07:22 PM |
red black and red orange(listed as red yellow but i think it looks orangey) with a black from the fan for the illumination earth and the red orange
from switch to positive illumination from what i remember. I havent actually got mine to work either and its how it came out the bag but the rad fan
worked instanty.
Adam
[Edited on 7/2/09 by bassett]
Krismc
| posted on 8/2/09 at 05:12 PM |
Mine was prewired and didnt work- why didnt they do a wiring diagram or in the list put the wiring colours to say what is what- instead of just 22.
fog, 23 fan....really helpful
i cant swap the red/yellow(or orange) as they are linked together.
[Edited on 8/2/09 by Krismc]
bassett
| posted on 8/2/09 at 09:12 PM |
Sounds same as mine Krismc nothing happens so i might have to re wire it. Asked Marc for a wiring diagram but he doesnt do the wiring so asked martin
griffin who makes the loom but he doesnt have on he makes it to MNRs request so there is no diagram - great!
Gergely
| posted on 9/2/09 at 09:11 AM |
Ours seems to work. Just got it working this weekend.
The fog light only works when the position lights are switched on, so ensure that you try it when you have those on.
I can't remember the colours now...
Gergely
Our build pictures
bassett
| posted on 9/2/09 at 11:17 AM |
Cheers Gergley that may be my problem as the side lights arent in yet but it still would be nice to get a wiring diagram as its a right pain
understanding the notes epecially with savage switches and hazard/indicators!
Adam
neilj37
| posted on 9/2/09 at 11:25 AM |
If i can find the wiring details for my MNR i can pdf them too you.
stuart_g
| posted on 9/2/09 at 11:50 AM |
The digram should help you out.
The red/black is the power feed to the fog switch and becomes live when the side lights are on.
The two red/yellow wires: one is the power feed to the fog light only live when the fog switch is on. The other short loop is the feed to the fog
switch illumination bulb (so it is only illuminated when fog switch is on).
Black is earth for the switch bulb.
The fog light end is self explanetry red/yellow to one side of bulb, black to other side of bulb.
I don't know the savage switch but I assume it has 4 connectors. If it only has 3 connectors leave off the red/yellow short spur as the wiring
for this will be done inside the switch. You may need to use a multimeter to find out which contacts are which.
[Edited on 9/2/09 by stuart_g]
Krismc
| posted on 9/2/09 at 08:40 PM |
It has 8 connections acutually, but yea ill need to use four of them:- 1) com 2) N/O 3) +LED 4) -LED
Your image doesnt seem to show on my computer, and i didnt relise that the fog runs only off the side lights/main beam, as my mini cooper works with
no lights on and even with the keys out and thats a 1996 model, so thought that would be normal.
Now i know how its supposed to be wired, that makes sense!
EDIT- you pic has now appeared.
[Edited on 9/2/09 by Krismc]
stuart_g
| posted on 9/2/09 at 09:45 PM |
Aaahh... now you have listed the connectors I would wire it up as follows.
1, comm (common) connect to red/black
2, N/O ( normally open) connect to red/yellow that goes to the fog lamp.
3, +LED connect to the red/yellow spur.
4, -LED connect to black (earth)
Let me know how you get on.
Krismc
| posted on 10/2/09 at 07:58 PM |
just been in garage today before i went to work and found its the savage switch that is faulty- you press the switch in fully and it makes the
contact, as you leave go it latches ok and switch stays in but the contact drops off(internally).
wiring is now fine, just the switch that is damaged.
