markyb
| posted on 7/2/09 at 07:11 PM |
boot cover
I am about to start to attempt to fit the CF effect boot cover and was wondering if anyone has any tips on how to go about it (accompanying photos
would be nice too ).
I have done a cardboard template but just want to make sure I am going about it the right way before cutting and making a horlicks of it.
thanks
stuart_g
| posted on 8/2/09 at 11:06 AM |
I also made a cardboard template, then transfered this to the CF sheet. I made cuts in the template from the Roll bars to the outside of the car.
Here's a pic.
markyb
| posted on 8/2/09 at 11:29 AM |
just what I was looking for - much appreciated
Johneturbo
| posted on 8/2/09 at 04:41 PM |
Thats the next job for me
last time i cut mine into 3 sections as i found it very difficult to get it all past the roll bar
might try the one piece method
Stu, are they Dzus fixings at the back?
stuart_g
| posted on 8/2/09 at 08:08 PM |
It is a bit of a job getting it to fit in one piece but I found it easier to fit it to the passenger side first due to the diagonal roll bar brace
then fit it round the roll bar/brace on the drivers side.
I secured it with the self tappers and black number plate screw covers that are supplied. I had only fitted 3 when I took the picture, they are fitted
all the way around.
markyb
| posted on 8/2/09 at 11:14 PM |
got mine cut today as per stuart's method and it worked out well - after a bit of trial and error I also found the only way to get it to fit was
by fitting the panel from the passenger side first .
joemotion
| posted on 25/2/09 at 07:18 PM |
where did you get the cover from? carbon mods?
Pdlewis
| posted on 25/2/09 at 07:44 PM |
I was going to use number plate screws/caps but from the picture they didnt look like theyd pass the radius test. these are the ones i was looking
at
caps this is the best
picture not the actual caps as these are super expensive
Build Photo Album
Updated 05/02/2009
maximill666
| posted on 25/2/09 at 09:14 PM |
at
Screw caps will pass sva ok, I used them on mine
