Author: Subject: Finished MNR - Pre SVA opinions please
bassett
posted on 22/3/09 at 02:55 PM Reply With Quote
Hi, Other than a few little bits like the mnr loan kit the car is finally assembled. I've added some pics and i hope other builders who've been through sva can point out any potential problems i have.
All comments welcome.
im planning during this week making a bumper bar for the front with front indicator that will hopefully prevent radius testing of the front suspension which mnr might supply. It will also have a cat and hopefully some heat wrap tied in place. And finally a boot box lid.
Thanks in advance
Adam
Paul TigerB6
posted on 22/3/09 at 02:58 PM Reply With Quote
Looks lovely mate.
Fog light lens needs to be vertical though.
blakep82
posted on 22/3/09 at 03:10 PM Reply With Quote
battery termoinal covers? can't see how the battery holds in eeither
________________________
posted on 22/3/09 at 03:13 PM Reply With Quote
Are your front brake hose OK? ie not touching lock ot lock and where they need the body need to be fastened to the chassis...
Nut covers on the battery terminals and some edge trim round the harness brackets??
Bottom of the dash will need some soft trim to make the 19mm radius as well.
And whys your roll bar not as high as mine
Good luck with the dept of Vosa...
omega0684
posted on 22/3/09 at 03:42 PM Reply With Quote
your rear reflectors look quite close the rear brake lights, are they the right distance away?
Pdlewis
posted on 22/3/09 at 03:44 PM Reply With Quote
Looks really good Adam
As above really Utrim on the seat belt tops and nut covers
Build Photo Album
Updated 05/02/2009
cloudy
posted on 22/3/09 at 03:47 PM Reply With Quote
Some of your front suspension requires nut covers...
www.warnercars.com
grazzledazzle
posted on 22/3/09 at 04:08 PM Reply With Quote
bit more photoshopping to do on tin top number plate
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 22/3/09 at 04:20 PM Reply With Quote
haha, strangely thats the first thing i noticed!
Seat belt bolts need nut covers and cover all the bolts in the wishbone area with nut covers.
clairetoo
posted on 22/3/09 at 04:23 PM Reply With Quote
Are the seat belt top mounts below the slots in the seats ?
Its cuz I is blond , innit
Claire xx
Will weld for food......
Omni
posted on 22/3/09 at 04:35 PM Reply With Quote
Man that looks SWEET!!!! Well done. I want
O
eddbaz
posted on 22/3/09 at 04:54 PM Reply With Quote
Looks sweet, harness looks like it's bolted too low for the slots in the seats.
westf27
posted on 22/3/09 at 05:21 PM Reply With Quote
Handbrake button looks tight on the radius,onle mention it because I failed on it
555
jonesier1
posted on 22/3/09 at 06:09 PM Reply With Quote
dont the mirrors have to fold in under a certain amount of pressure,ie if they were hit ? looks like they would fold up!!!.not 100% sure.Really nice car though
ReMan
posted on 22/3/09 at 06:19 PM Reply With Quote
Looks great.
Mirror mountings edges?
Front of silencer edge?
Slater
posted on 22/3/09 at 06:23 PM Reply With Quote
Fog light needs to at least 100mm away from stop light.
Put some spiral wrap on your braided front brake hoses.
Good quaility build, by the way!
Humbug
posted on 22/3/09 at 07:01 PM Reply With Quote
I think it's only for "normal" cars where the mirrors stick out beyond the overall edge. For sevens this would be a line from the outside of the front arch topthe outside of the rear arch, so should be OK.
However, the base of the side mirrors looks like it might be a bit too sharp radius-wise - a bit difficult to see from the pics, but worth a check.
Good luck
Simon
bassett
posted on 22/3/09 at 07:02 PM Reply With Quote
Thanks guys keep them comming. A few of the points mentioned i have stuff for ie seat belt trims, terminal covers although enormous ones.
Brake hoses are attached to the chassis after they enter through body so i hope thats ok.
Do mirrors need to fold in as they dont come out as far as the arch?
Il check fog is away from brake - never checked though.
Not sure what i can do with seat belts as they do go up to the seat, its been mentioned before but they are bolted straight to the floor with only spacers to clear the chassis rail. any ideas what i can do?
Steve this is our second chassis as first one had giant man sized roll bar being a shortish man 5"10 and as requested at order mnr took it back and gave us a new one still within safe limits though even with helmet on measured to front of chassis.
is there anyway to get fog light vertical?
Thanks for all comments so far. New problem arisen though - car no longer starts why me!
Johneturbo
posted on 22/3/09 at 08:02 PM Reply With Quote
Looks good Adam
If your seats are bolted to the floor with only clearance for the chassis then it should be fine.
maybe the pic angle makes it look worse than it is
a strap for the battery needed too.
edited ie foglight add some u trim on the upper part of the housing to get it more vertical
[Edited on 22/3/09 by Johneturbo]
jambo
posted on 22/3/09 at 08:03 PM Reply With Quote
nice car.
regarding the seats,mine were the very same.
what i did was 30mm spacer at the front and nothing at the back,this will get it right although you will have to play around with position to miss the diagonal rail.
ps. mine have sliders aswell.
if you dont have sliders then its the same idea you may have to go with something like a small spacer at the back and 25 to 30mm taller at the front.
Pdlewis
posted on 22/3/09 at 08:04 PM Reply With Quote
To get the fog light vertical get some 6mm coolant hose and put between the carbon surround and the body then you can tighten up until the light it vertical
Build Photo Album
Updated 05/02/2009
bassett
posted on 22/3/09 at 08:27 PM Reply With Quote
Thanks again everyone. So for the rear lights have they all got to be vertical or just the fog light. doesnt sound too difficult with the above suggestions.
Seat on the other hand il try and angle the spacers. Should i try and raise the mounting hole with some washers or would this make it more unstable with less threads from the testers point of view?
Adam
bassett
Adam
