Krismc
posted on 17/4/09 at 01:03 PM |
Failed Sva - Newcastle
I failed at newcastle but most of the items i did while i was there but he had already wrote them on sheet.
1) Steering rack extensions - No lock nut at track rod end (there is one at rack end)
2) OSF top suspension arm is not 2.5mm- Bit of U-Trim to sort
3) Front Mud guards no trim on inside- U Trim again- DONE
4) Rear Reflectors not to 2.5- Dremal and sandpaper
5) Dash lower edge not 19mm - NOT SURE WHAT TO DO!!
6) Interior panels not 2.5 - U trim - DONE
7) NS body panel effected by exhaust- cut hole bigger
8) Rear suspension Arm Bolt into hub have no spring washers.
9) Rear position of stop lamps 8mm too low - raise ride height
10) Mirrors distorted from vibration - Put Plates on back possibly
..... and the biggy
11) Emmissons should be 0.2 and they are 5.3 (oh bleep thats bad isnt it)
Havent a clue what to do with emmissions i got ripped out more than enough for the ECU tuning.
Kris.
[Edited on 17/4/09 by Krismc]
Krismc
posted on 17/4/09 at 01:05 PM |
My suspension is at full height at rear and i cant raise it anymore and i can just get my fingers under the wheelarches.
Probs get another 10 mm MAX on strut if i had stronger arms.??? is this normal to have suspension topped out at ride height- surely this will make the
back a harder ride??
And what can i do with dash??
posted on 17/4/09 at 03:14 PM |
Springs are the wrong length Kris, give Chris a call and I'm sure he'll sort you out.
Krismc
posted on 17/4/09 at 05:25 PM |
Thats what i was thinking also- Springs/Dampers are very short.
Im actually gutted about the dash board- The bottom radius is wrong size not 19mm, the only thing i can do with it is cut/drill the dash and fit foam
to bottom edge as it has to be permantly fixed or glued!?!?!
Why dont MNR change the mold to meet SVA- Or have they?? im just really frustrated that ive payed all that money for a carbon fibre dash board and i
have to wreck the bottom inch of it.
Johneturbo
posted on 17/4/09 at 05:30 PM |
Something doesn't sound right with the rear!
you do have the longer shocks at the back!?
Krismc
posted on 17/4/09 at 05:40 PM |
I remember having a problem with fronts, I had to get longer push rods.
Any one know what lenght they should be.
James
posted on 17/4/09 at 05:46 PM |
Jacking up and therefore wrecking your rear suspension setup to get the lights through is a bit drastic/a bodge isn't it?
Can't you just raise the lights a bit?
As for the dash. Can you glue a 19mm radius rubber tube under the bottom edge? At the end of the day it's to protect your legs in a crash so
having it there permanently may not be the end of the world!
James
- Muhammad Ali
Johneturbo
posted on 17/4/09 at 05:58 PM |
Sounds like the rear isn't high enough if you can only get 1 finger under the arch.
i had mine that low( 1 finger under arch) and got tyre rub on hard cornering so i've had to the raise the rear, about 2 fingers worth
with the dash how about some pipe lagging?
Krismc
posted on 17/4/09 at 08:09 PM |
Mike Cookson came to SVA center with some lagging (cheers mike) but tester said that is not permanent enough, i have to cover it with vinal and glue
or bolt it.
Krismc
posted on 17/4/09 at 08:12 PM |
James
I dont know if i can raise lights without damaging the TUB and my dash is carbon fibre, so dont want to spoil it and only has to be protected on the
passenger side.
vindicator
posted on 17/4/09 at 09:16 PM |
For the dash, can you not replace the CF one with a ply made up one. Does not have to be preistine at this stage as the CF will be put back on later.
It may be cheaper than destroying a CF dash.....
HTH
TimR
timr.spaces.live.com---build blog
Krismc
posted on 18/4/09 at 10:13 AM |
The Scuttle and the dash are all one piece on the MNR- its basically a box with the bottom bit open so you can put the wiring under- nice and neat.
GeorgeM
posted on 18/4/09 at 10:47 AM |
Kris,
is the bottom edge of your scuttle not rounded??
GeorgeM
Krismc
posted on 19/4/09 at 10:32 AM |
Yea the bottom is rounded, but its too sharp it has too be 19mm radius.
Krismc
posted on 19/4/09 at 10:37 AM |
HERE IS MY DASH
richardh
posted on 19/4/09 at 02:51 PM |
it looks fine to me
mine is all orange but looks the same and i had no issues.
is he checking right underneath where the mould ends?
sounds like examiner is a bit anal to me.
like the scoop - where did you get yours from??
Krismc
posted on 19/4/09 at 04:19 PM |
Scoop is MNR's but its £80
vindicator
posted on 19/4/09 at 09:48 PM |
ok, now I see the whole thing.....you live and learn.....
bassett
posted on 20/4/09 at 07:55 AM |
My dash looks exactly like yours but with the gloss black insert and it was never even questioned. You sure he isnt on about the dash bars as that was
a failure point on mine as the ally scuttle piece wasnt radiused so ive covered it in rubber mat.
for the mirrors have you got rubber trim/foam trim between the scuttle and tub as that should reduce vibrations and doing the same between the mirror
and scuttle might help dampen it slightly. if you need to change mirrors, cbs mirrors although slightly unsightly are fine for the job.
Adam
Davey D
posted on 20/4/09 at 02:45 PM |
Where my mirrors bolt through the sides of my scuttle panel i have bonded some 2mm alu flatbar in plate to strengthen it, and help reduce
flex/vibrations
Krismc
posted on 20/4/09 at 07:50 PM |
Thats what i planned with steel, but if ally does the trick ill try that.
sucksqueezebangblow
posted on 21/4/09 at 08:19 AM |
Hi Krismc,
Sorry, different subject, but what car is the gear leaver gaiter on your car off? And where did you get it?
I have a Serra handbrake gaiter that the parts place found under layers of dust on a forgotten shelf but they did not have and could not get a Sierra
gear lever gaiter so I'm after one, or something similar like yours.
Krismc
posted on 21/4/09 at 03:52 PM |
its a sierra one, standard just chopped down
DarrenW
posted on 22/4/09 at 02:32 PM |
or bolt it.
I fitted a special bit of trim to my dash on passenger side to make sure i didnt fall foul of the rad rules. Steering wheel side is largely behind the
exempt area.
Krismc
posted on 22/4/09 at 07:06 PM |
You got any pics of what you have done to dash to pass SVA- he only wants passenger side sorted just like you say the rest is exempt!
