Triggerhappy
posted on 4/5/09 at 09:46 AM |
Front end help VortX Super
Can somebody please post some clear instructions (pic´s) on.
1: Fitting "raceleda" front hub...what washers go where when fitting on a-arms??
2: Steering link to Steering arm on hub. The hole in steering arm is much bigger than tapered axle on steering link.
The link is also hooked, should the "hook" (bend) face forward or rearwards?
Would be soooo greatful for any help.
spdpug98
posted on 4/5/09 at 11:04 AM |
Hi if you drop me your email address I will send over the pics I have, from when I put mine together
Looks like you are missing the tophats that go into the hole for the track rods ends to fit in, mine where missing from my kit but Chris sent them out
next day
My Blog: http://spdpug98.wordpress.com/
Bigheppy
posted on 4/5/09 at 11:08 AM |
Have a look at this thread. I dont know which type you have but some uprights have rod ends which require the use of adaptors.
link
spdpug98
posted on 4/5/09 at 11:12 AM |
Managed to find these, hope they are of some use:
Triggerhappy
posted on 4/5/09 at 11:30 AM |
GREAT!!
Those steering link top hat´s is what i miss.
Front hub set up = GREAT!
Still confused about:
spdpug98
posted on 4/5/09 at 11:44 AM |
Do you mean the link bar for the track rod end, if so mine face towards the disc rather than the chassis, these pics may help: (taken before I had my
tophats!)
[Edited on 4/5/09 by spdpug98]
sucksqueezebangblow
posted on 7/5/09 at 04:04 PM |
quote: Originally posted by Triggerhappy
GREAT!!
I checked this with Marc before fitting mine. The link should curve forwards to the pivot. In other words the tapered pin going through the steering
arm (attached to the upright) should be forward of the centerline (axis) of the steering rack rod the link screws on to.
[Edited on 7/5/09 by sucksqueezebangblow]
Krismc
posted on 7/5/09 at 04:49 PM |
I thought for the price i payed for the raceleda uprights the bolts would have been a decent spec- but mine are 3 years old now- car hasnt been in wet
or on the road(still building) and they are rusty - the calliper bolts are shocking.
