bassett
posted on 3/6/09 at 07:12 PM |
Power commanders TPS %
Hi, whilst setting my emissions at the weekend gone i realised ometimes my pc3 software doesnt read a throttle position - stays at zero. Anyone know
what would cause this? Will it have adverse effect when actually running?
Adam
[Edited on 3/6/09 by bassett]
Davey D
posted on 3/6/09 at 07:49 PM |
[Edited on 3/6/09 by Davey D]
Davey D
was you pressing the throttle pedal when it was reading 0% or had you just used the thumb screw adjuster?
bassett
posted on 3/6/09 at 08:03 PM |
i was using the pedal and nothing but had previously been fiddling with the idle screw.
Agriv8
posted on 3/6/09 at 08:21 PM |
does it alway read when the car running ? on some tps wont read with just ign on
regards
Agriv8
[Edited on 3/6/09 by Agriv8]
bassett
posted on 3/6/09 at 08:37 PM |
I had thought that as what ive noticed is it always seems to work when its gone from off to started but then after running it and changing mapping it
then has not tps% - confirmation of your point would be great though.
Agriv8
posted on 4/6/09 at 07:04 AM |
What age engine are you running ?
dan__wright
posted on 4/6/09 at 07:24 AM |
have you tried calibrating it?
bassett
posted on 4/6/09 at 05:49 PM |
its an 02-03 model r1 (5pw)
How does the calibration go?
Davey D
posted on 8/6/09 at 08:16 AM |
i cant remember the exact menu option, but somewhere you can set the throttle calibration where you have to fully press the throttle, so it knows
where the end point, and start point are. once that is done the power commander knows what % the throttle is when driving
bassett
posted on 8/6/09 at 08:55 PM |
Cheers Dave - Il have a flick through the manual although last time i read it, it was more what everything means on the screen rather than how to use
the product for the purpose intended.
Davey D
posted on 8/6/09 at 10:05 PM |
just had a quick look in the program you need to click: Power Commander Tools, then Set Throttle position. you can only do this with the power
comander powered up, and connected, which on the newer R1 the engine has to be running to power up the power commander
bassett
posted on 9/6/09 at 12:04 PM |
Thats great, il give it a go tonight and hopefully il have a sva'd car by friday
