Author: Subject: Raceleda Pad rattling
maximill666
posted on 10/7/09 at 08:47 PM Reply With Quote
Anyone have any ideas how to stop the pads rattling on Raceleda 4 pot calipers when not being applied?
Or is it just something that has to be put up with?
INDY BIRD
posted on 10/7/09 at 08:49 PM Reply With Quote
mmmm i know the feeling mine also do that especially if you just rock the car back and forward,
would like any ideas also
sorry couldnt help though
blakep82
posted on 10/7/09 at 08:57 PM Reply With Quote
i know copper grease is mainly used to stop brake pads squealing, but would it help stop them rattling?
________________________
a4gom
posted on 10/7/09 at 09:05 PM Reply With Quote
I have outlaw calipers they are very similar infact they could be the same with a different name cast on, anyway I've chosen to live with it. Copper grease will help but notstop it for long. I have however seen some use double sided sticky pads between the pad and the pistons, others do something with a spring from a biro on the retaining pin and others use the standard pressed retaining from a standard car model (can't remember which) there have been quite a few threads on the subject so have a search. If you can't find it on here check on WSCC, it could have been on there.
have a look at this, means new pads or grinding your tabs off though
[Edited on 10/7/09 by a4gom]
Perfect planning prevents pi$$ poor performance!
maximill666
posted on 10/7/09 at 09:28 PM Reply With Quote
Cheers a4gom thats great
tonym
posted on 11/7/09 at 08:40 AM Reply With Quote
Try a bit of silicon sealant on the back of the pads
richardh
posted on 11/7/09 at 10:44 AM Reply With Quote
good ideas. i'm fed up with the rattle too
Time for a change!
stuart_g
posted on 11/7/09 at 02:55 PM Reply With Quote
All you need to do is increase the size of the sleeve that the retaining bolt goes through. I think when I measured up it needs to be 12mm rather than the 9mm I think it is now. If you have the Raceleda discs your pads will overhang the disc so the sleeves can be the same thickness all the way accross. If you get discs that fit properly (257mm) then the sleeve will need to be 8mm in the middle for the disc to clear and 12mm each end.
[Edited on 11/7/09 by stuart_g]
procomp
posted on 13/7/09 at 06:58 AM Reply With Quote
Hi
It's a common problem with the outlaw's which is what the raceledas are with a different name etched on them. It's due to the lack of wear shims where the pads are effectivly sitting and as said the pins to small in diameter. It needs to be stopped from happening as the pads will start to wear the caliper body away and create a ridge which the pads can dig into giving all sorts of problems later in there life.
But to be fair these are the sort of calipers that the Americans treat as disposable items hence very cheaply made and do not come with the stainless shims that other caliper manufacturers engineer in to the desighn.
Cheers Matt
spdpug98
posted on 13/7/09 at 08:04 AM Reply With Quote
A bit off topic-
This is something I noticed when I built my car, why do they supply a 'differant' disc size with the callipers.
Has anyone changed their discs so that they fit correctly within the calipers/pads.
It does seem strange that the lower 10/12mm of the disc does not get used, and then have an overlap from the pads as they wear
[Edited on 13/7/09 by spdpug98]
My Blog: http://spdpug98.wordpress.com/
stuart_g
posted on 13/7/09 at 08:46 AM Reply With Quote
I looked into this for a long time. The hardest part was finding a disc of the correct offset and size as a cortina disc is 248mm. I also looked into different manufacturers brake pads but they were virtually all the same size.
The only thing I came up with was to fit a 260mm escort solid disc and have it turned down to 257mm. These discs are almost the same offset as Cortina and just required a washer placed between the caliper and mounting bracket to bring the caliper back to the centre of the disc. I got these from Hi Spec Motorsport in Dartford as they were the only company I found that could actually help with the problem. The result as you can see in the pictures is that the whole of the pad is now in contact with the disc increasing the area of contact on the disc. Hi Spec didn't even charge for turning the discs down.
I didn't get my lathe up and running before I sold my car otherwise I would have made the larger retaining sleeves to stop the pads rattling so much. If the sleeve is bigger in diameter it will hold the pad further into the caliper against the body so the pad will not be able to twist and move forwards and backwards thus eliminating the rattling. Don't make the sleeves too tight though as you do not want to restrict the pads movement and risk the pad binding.
I think this is a mod well worth doing.
R16 New disc at hub
R16 New disc at hub
[img][/img]
[img][/img]
[Edited on 13/7/09 by stuart_g]
spdpug98
posted on 13/7/09 at 08:51 AM Reply With Quote
I looked into this for a long time. The hardest part was finding a disc of the correct offset.
The only thing I came up with was to fit a 260mm escort solid disc and have it turned down to 257mm. These discs are almost the same offset and just required a washer placed between the caliper and mounting bracket to bring the caliper back to the centre of the disc. I got these from Hi Spec Motorsport in Dartford as they were the only company I found that could actually help with the problem. The result as you can see in the pictures is that the whole of the pad is now in contact with the disc increasing the area of contact on the disc. Hi Spec didn't even charge for turning the discs down.
Thanks, just what I was looking for. I just wish I had seen this mod before I finished building mine.
I will have to add to my 'mod' list
