55ant
posted on 3/9/09 at 10:19 AM |
bike carbs for pinto
im after a bike carb setup for a mk running a 2.1 pinto
im hopefully after the whole setup, filter carbs manifold fuel pump. post or collect from anywhere around london/cambridge
cheers all, either pm or email
ant.collier@gmail.com
thanks
omega0684
posted on 3/9/09 at 11:20 AM |
if you can't get hold of a full set up its not that difficult to do it yourself,
get a set of bike carbs of ebay,
get someone to make a manifold if you cant do it yourself (bogg bros etc)
low pressure red top fuel pump
easy
ashg
posted on 3/9/09 at 01:47 PM |
sorry for the hijack but could someone clarify why you cant use the pinto's fuel pump?
im planning to go down the bike carb route and was wondering if there was any way of keeping the old vac distributor and fuel pump?
my knowledge in this area is somewhat limited as i am more of an efi man
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
cd.thomson
posted on 3/9/09 at 02:00 PM |
you need a high flow low pressure fuel pump to supply carbs.
If you've got an efi (pinto or otherwise) pump in front of you then the pressure it produces is going to completely overload your carbs and they
wont be able to control the fuel flow properly.
If you've got the pump from a carbed pinto sierra then this might work, but I suspect it wont flow anywhere near fast enough to provide enough
fuel for the high performing bike carbs.
Craig
andrewcutchey
posted on 3/9/09 at 02:16 PM |
Bike carbs really need matching bike fuel pumps. Then you do not need to worry as the pump supplies enough fuel at exactly the right pressure. It
switches on as the pressure drops and switches off when full pressure is reached.
ashg
posted on 3/9/09 at 02:42 PM |
its a carbed 1.6 pinto that i have with the mechanical fuel pump
the bike carbs i have to go on are off a zx6
the problem i have at the moment is that the pintos weber carb is too tall and i dont want to cut a hole in my bonet as it would be half on the bonet
scoop and half off the scoop.
the plan was to make a manifold and fit the bike carbs to avoid a hole half on and half off my bonet scoop.
i didnt really want to spend a fortune on it because i want to fit a new zetec or duratec after iva.
so if i find a zx6 fuel pump get rid of the pinto mechanical one will that be better?
also what should i do about the vac advance on the distributor? can i just connect it to one of the ports on the new inlet manifold?
the goal at the end of the day is not to tune the balls out of it. it is to get it running within the emissions regs to pass iva without hacking up
my bonet.
cd.thomson
posted on 3/9/09 at 02:59 PM |
55ant, think of these posts as free bumps
yes a zx6 fuel pump is going to be your best bet as far as setting the thing up properly goes, you wont have to worry about aftermarket fuel pressure
regulators etc.
I believe on the vac advance side of things your options are leave it off, fit an electronic dizzy or fit megajolt.
Craig
andrewcutchey
posted on 3/9/09 at 03:00 PM |
A bike fuel pump will be better than the pinto mechanical pump and a regualator and possibly cheaper.
Ideally you want to run it with a vacuumless dizzy or a megajolt.
Like any carbs you'll still need to get the carbs running right as it is not often that they are totally plug and play.
ashg
posted on 3/9/09 at 03:11 PM |
just looked at zx6 fuel pumps on ebay. they cost more than i paid for the carbs
what detrimental effect would it have leaving the vac hose off the distributor? i assume it will prevent ignition advance when crusing resulting in
crap fuel enonomy? or is that wrong.
i want to try and keep it locost as it wont really be a long term solution. when i change over to ze/dura i plan to go throttle bodys with megasquirt
so the carbs etc will become redundant.
[Edited on 3/9/09 by ashg]
