Author: Subject: Brake caplier 4 pot
luke123456
posted on 7/9/09 at 10:56 PM Reply With Quote
Brake caplier 4 pot
I have just purshased a second hand voxtx, and have notice a few funny nosies.
The question is........ i have the race leda 4 pot capliers (r-16) fitted on the front, and the brake pads seem to be lose fit in the caplier, there is pin which holds the pads in, but should there be some kind of shim fitted??
Luke.
austin man
posted on 7/9/09 at 10:58 PM Reply With Quote
are the brakes coming on ?? sure you haven't got a sticking piston.
luke123456
posted on 7/9/09 at 11:03 PM Reply With Quote
brakes work well, i have the car on the ramp at this time and the wheels turn fine when the brake is off. The car has only done 1400miles and on 2008 plate.
austin man
posted on 7/9/09 at 11:06 PM Reply With Quote
one piston gould be stuck in ??
luke123456
posted on 7/9/09 at 11:15 PM Reply With Quote
It's like the there should be a spring or a shim to stop the brake pad rattling around in the caplier. Should there be one fitted!
maximill666
posted on 7/9/09 at 11:45 PM Reply With Quote
Luke it's a common problem with the outlaw's which is what the raceleda calipers are with a different name etched on them. It's due to the lack of wear shims where the pads are sitting and the pins too small in diameter. It needs to be stopped from happening as the pads will start to wear the caliper body away and create a ridge which the pads can dig into giving all sorts of problems later in there life.
All you need to do to stop it is increase the size of the sleeve that the retaining bolt goes through. It needs to be 12mm dia rather than the 9mm
Or do this
http://boardroom.wscc.co.uk/cgi-bin/ikonboard.cgi?act=ST;f=3;t=62248;st=0;r=1;&#entry632313
[Edited on 7/9/09 by maximill666]
luke123456
posted on 7/9/09 at 11:54 PM Reply With Quote
Have a set of this Willwood capliers on my rally car, and very handy i have a spare set of new pads kicking around.
Luke.
