mr henderson
posted on 25/11/09 at 05:00 PM |
Electric guitar set up tips
I expect most of you will already know this, but for those that don't-
If you are adjusting the intonation, it's always best to start with a new set of strings, and while the strings are off, wind the bridge pieces
back towards the tailpiece. There's 2 reasons for that, first, it's always easier to wind the bridge pieces forwards when the strings are
back on that it is to wind them back, and second is that when the strings are tightened, they can get a slight kink where they rest on the bridge, and
that can affect the intonation. If the bridge is already back as far as it will go, then that kink will be the otherside of the bridgepiece when it
moves torwards the neck, and so won't matter.
Apologies to the guys that already knew that, just one of those little tips that makes life easier.
mr henderson
posted on 25/11/09 at 05:08 PM |
Checking pickup phasing
Don't throw away your old analogue meter, if you've got one
When getting ready to install a new pickup to be used in conjunction with another pickup from a different maker, you can check the phase of each
pickup by connecting the meter across the output and putting it on a sensitive dc volts scale.
Then, put a piece on metal on the pickup, and sharply pull it off. Looks to see which way the needle moves. Then check the other pickup and if the
needle moves in the same direction, you'll know it's in phase. If not you will need to reverse the wires on one of them.
Liam
posted on 25/11/09 at 05:23 PM |
And don't forget to turn up to 11 when finished.
Johneturbo
posted on 25/11/09 at 05:34 PM |
Can't you just make 10 louder.
RK
posted on 25/11/09 at 05:45 PM |
No you need 11 or it doesn't work
mr henderson
posted on 25/11/09 at 06:59 PM |
Does your truss rod need adjusting?
If you're not sure, try this simple tes-t hold the 3rd string down at the first fret, and the top fret. If you can see a slight gap between it
and the frets halfway along then that's right. The gap should be big enough to see, but no more.
If you're not sure there is a gap, try picking the string between the two fretted positions. It should sound cleanly, but make sure it's
not resting on one of the frets in between by moving the fretting fingers one fret and making sure the note changes.
If you have to back the trussrod off, give it a little while to settle before you check again. If you have to tighten it, try to bend the neck forward
a bit to take the strain off the trussrod nut, sometimes they stick and the trussrod can break (fairly common on Fenders at one time)
posted on 25/11/09 at 07:36 PM |
have you won a Gibson SG on ebay?
mr henderson
posted on 25/11/09 at 07:52 PM |
posted on 25/11/09 at 08:19 PM |
I assumed that you have come into possession of a guitar hence posting tuning tips.
Brian James of the Damned had one.
[Edited on 25/11/09 by 02GF74]
mr henderson
posted on 25/11/09 at 08:26 PM |
Actually set up tips, I'll leave the tuning to the players.
The guitar thread yesterday showed that a lot of people here played, so as I spent a few years as a guitar repairer/technician I thought I'd
post up a few tips. But if it's not going down too well, perhaps I should delete the thread?
[Edited on 25/11/09 by mr henderson]
mangogrooveworkshop
posted on 25/11/09 at 10:35 PM |
I need a hand with a neck replacement ........its a les paul copy that the young one dropped after three days of ownership knocking the top off
ive got a replacement neck but need to make a jig for the router to clean the socket out square. Haven't got round to it but its all complete
mr henderson
posted on 26/11/09 at 08:37 AM |
My inclination with a job like that would be to clean the socket out with a sharp chisel, not worrying too much about creating gaps, and trying the
neck from time to time until it fitted, lined up with the bridge properly and at the correct angle so that the strings didn't end up either too
high or too low across the bridge.
Then I would glue it in with Araldite (not the rapid) which I would heat with a hairdryer until all the bubbles came out (goes transparent) and its
consistency was freer, then glue it in and clamp it and leave it for 12 hours or so. Any squeeze out I would remove with acetone before it set, or
trim with a sharp blade while it was cheesy (couple of hours).
I always used araldite for that sort of thing (unless it was a vintage instrument) because it is strong and it fills gaps. Good for broken headstocks
as well, because the fibres rip apart and by the time they are removed so the head fits properly, there are always gaps
posted on 26/11/09 at 11:59 AM |
I spent a few years as a guitar repairer/technician I thought I'd post up a few tips. But if it's not going down too well, perhaps I
no objections at all. good tips and common sense once you know about it.
mr henderson
posted on 27/11/09 at 04:27 PM |
I thought I would get more feedback (even if only negative ) form this.
Would anyone like to know about a quick, easy and accurate way to do a fret dress?
rgdavid
posted on 27/11/09 at 05:03 PM |
yes please,
& i like your phrase of wanting more "feedback"
