The Venom Project
posted on 9/3/10 at 04:45 PM |
Nosecone Grill
How do you guys fit the mesh to the nose? Is it bonded on with silicone? Is it screwed into blocks? Have my mesh, but no solid clue what to do, I
have a few ideas, but just wondered what everyone else has done?
Nick
[Edited on 9/3/10 by The Venom Project]
dunk3
posted on 9/3/10 at 04:52 PM |
I used some sikaflex to bond 4 peices of wood to inside of the nosecone, and then screwed the grill to the wood, there are some photos in my archive.
sucksqueezebangblow
Hi Nick,
I used the off-cuts from the rear wheel cut-outs in the body. I used the 90 degree angle in one of the off-cuts to make 5 angle brackets. I glued
these into the inside lips of the cone with epoxy resin and then, once set, overlaid the grille from the inside and marked the bolt positions on the
brackets. I then drilled the brackets and fitted rivnuts, and then bolted the grille in with ally bolts
![](/galpreviews/Grille.JPG) ![VortX Grille](/gallery/Grille.JPG) VortX Grille
[Edited on 9/3/10 by sucksqueezebangblow]
twybrow
posted on 9/3/10 at 04:55 PM |
I bent mine around the inside of the nose cone, and used PU adhesive to hold it in place...
iscmatt
posted on 9/3/10 at 05:06 PM |
Mine is bent around the lip and the attached with 4 zip ties, makes it easy to remove, especially for cleaning when its full of bugs!
Humbug
posted on 9/3/10 at 05:40 PM |
I bonded 4 bolts behind the return with fibreglass mat and resin, then fixed the grill with washers and nylocs
spdpug98
posted on 9/3/10 at 05:41 PM |
I did the same
My Blog: http://spdpug98.wordpress.com/
richardh
posted on 9/3/10 at 06:02 PM |
Same as Humbug for me
Time for a change!
Wheels244
posted on 9/3/10 at 09:16 PM |
I did the same
Me too
3\4" dowel fits well between the slats - I sanded a flat onto them - bonded in with PU and then self tappers to fix grill to dowels.
Krismc
posted on 9/3/10 at 10:04 PM |
I forced it in and crossed my fingers
