Author: Subject: Brake Master cylinders, Bias bar etc
PuppiesBalls
posted on 13/4/10 at 12:35 PM Reply With Quote
Good afternoon gents,
I need to order a pair of master cylinders for front & back brakes , and the bias bar assembly,
Does anybody know where i could get all this from at a good price?
I think the remote adjustment knob would be handy too
Any advice when choosing the cylinders? (make/size/fitting etc)
Im using sierra discs & calipers all round at the moment but i might be changing to 4 pots if some pop up cheap
[Edited on 13/4/10 by PuppiesBalls]
posted on 13/4/10 at 01:21 PM Reply With Quote
Unless your are building for mainly track use a balance bar is not a good idea.
A remote adjustment knob is not a good idea and is 100% not allowed for IVA. Twiddling with brake balance is dangerous even on a circuit racer a balance bar set up its is normally once to the a standard dry weather setting, then for wet conditions it is a standard half turn or full turn to the rear.
For road use you want a smaller bore tandem dual circuit master cylinder.
PuppiesBalls
posted on 13/4/10 at 02:05 PM Reply With Quote
Thanks for the advice,
why is a single, double function cylinder better?
andkilde
posted on 13/4/10 at 02:16 PM Reply With Quote
Your IVA test doesn't allow adjustable brake bias -- so you're restricted there if you want to get it road registered. Dual circuit is for safety, a leak/failure at one end still leaves you with brakes on the other pair of wheels.
You might be able to use twin masters if you replace the adjustable pivot with a fixed one, not 100% sure if that"s OK though.
Cheers, Ted
PuppiesBalls
posted on 13/4/10 at 02:27 PM Reply With Quote
The car is already road legal
I think id still like dual master cylinders as the pedal box is designed for it & has the mounting holes for them
any suggestions where to get the bits from?
posted on 13/4/10 at 03:26 PM Reply With Quote
Rally Design.
eddie99
posted on 13/4/10 at 03:52 PM Reply With Quote
Rally Design for that stuff!
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
PuppiesBalls
posted on 13/4/10 at 11:04 PM Reply With Quote
What sizes do you reccomend I go for dudes?
Is there any advantage with the integral type?
