Author: Subject: Oil Galley Plugs
Seven_Monkey
posted on 22/4/10 at 08:45 AM Reply With Quote
Oil Galley Plugs
Hi all, the oil galley plugs on my Xflow block will not budge - has anyone got any tips for removing them?
I'm trying to rebuild the engine and I want to renew these plugs and clean out the galleys.
Rich
Build Thread - http://www.locostbuilders.co.uk/viewthread.php?tid=134121
snapper
posted on 22/4/10 at 10:14 AM Reply With Quote
If they are screw in then some heat always helps
I eat to survive
I drink to forget
MakeEverything
posted on 22/4/10 at 10:29 AM Reply With Quote
If youre clearing out the opilways anyway, then how about drilling some holes across the centre to weaken it, and use a hammer and cold chisel to bend it and get them out?
Kindest Regards,
Richard.
posted on 22/4/10 at 06:47 PM Reply With Quote
Try using a drift down the center of the hexagon and give each plug a few good clouts then using a good correct size Allen key to undo them . I used a bit of extra leverage when I did mine as they were pretty tight.
