The Venom Project
posted on 23/5/10 at 09:09 PM |
Brake Bias Bar
A week ago I took this item off my car as the IVA people would have failed it. When I arrived at MNR on Saturday I was told I could refit the item as
they had changed the regulations. Its no wonder people pull there hair out with worrying about the IVA test.
I have set my mind at rest now that my car will fail its initial IVA test, but hopefully within the 5 day free retest window I can fix whatever the
issue's will be.
It's not that i'm lazy, it's that I just don't care.....
Davegtst
posted on 23/5/10 at 09:27 PM |
AFAIK there is no problem having them fitted but once set they have to be permanantly fixed (welded or threads destroyed) to get through. If not then
i am getting one.
The Venom Project
posted on 23/5/10 at 09:29 PM |
Nope, new rule seems to allow them now, how bloody annoying LOL, I did remove it for a fixed bar, but now they have changed the rules.
bi22le
posted on 23/5/10 at 09:40 PM |
i have not touched my bias bar since i got the car! Its a good bragging point but im just too sacred to touch it!
Please read my ring story:
SteveWalker
posted on 23/5/10 at 09:56 PM |
All genuflect towards bi22le!
RK
posted on 24/5/10 at 12:46 AM |
I can't get mine to do anything.
AdamR
posted on 24/5/10 at 08:00 AM |
Are you 100% sure about that? Bias bars have always been allowed AFAIK, but only if the brakes pass at every possible setting, which is very unlikely.
cd.thomson
posted on 24/5/10 at 08:44 AM |
no definitely not allowed unless fully welded along all threads.
I was tested against the latest edition last wednesday
Craig
posted on 24/5/10 at 09:27 AM |
You can get some pills for that
marc n
posted on 24/5/10 at 10:55 AM |
no definitely not allowed unless fully welded along all threads. I was tested against the latest edition last wednesday
it was a known update that comes into effect at 9 am this morning i believe. you are allowed a bias bar assembly but the assembly once set must be
fixed with a locking device to disable further adjustment. as far as im aware acceptable locking is a roll pin, lock nuts and spacers . pretty much
anything that requires tools to remove.
im hoping to ring this afternoon and confirm the exact wording and will update on here as soon as i have full clarification
best regards
marc
please email rather than u2u
chrismnrltd@btinternet.com
Blackbird Rush
posted on 24/5/10 at 11:31 AM |
Mine failed on this earlier in the month as i had not disabled the adjustment (just had a locknut) i knew it would fail but wanted to bea ble to set
it up at the test, as it happened it passed where it was and all needed to do was weld it up, which i have now done!
Does seam strange that they would relent on the ruling and go back to the early SVA rule of just roll pin locking the bar??
Ash.
PeteS2k
posted on 24/5/10 at 12:16 PM |
That would've saved me a lot of hassle! Had to weld it, (fail on rear brake performance), cut it off, re-set a new one and get that welded to
get a pass. Less than 2 weeks ago... And they did check it, too...
Ho hum. Water under the bridge...
wicket
posted on 24/5/10 at 12:59 PM |
Gone back to how it was done in SVA days then.
eddie99
posted on 24/5/10 at 01:05 PM |
I hope it is going back to the original SVA way.... Keep us posted!
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
marc n
posted on 27/5/10 at 08:32 AM |
update for you all the new version of the manual is now released ( got the email this morning ) it still says version 4 but it is infact version 5
page 84 has the information, basically a sticker will need to be attached in the area around the bias adjuster with the wording in note 6 . i am
having some made , cost to anyone who needs one is £2.50 plus the cost of a stamp
new manual found here
www.businesslink.gov.uk/Transport_Theme_files/124_IVA_M1_Inspection_Manual__Version_4_0510.pdf]new manual[/url]
best regards
marc
[Edited on 27/5/10 by marc n]
40inches
posted on 27/5/10 at 10:52 AM |
"Note 5: Bias bars and other mechanical adjusting devices fitted to twin master cylinders must be rendered inoperable by mechanical means
e.g. lockwiring of components."
From new regs as pointed out by Marc
40inches
posted on 27/5/10 at 10:57 AM |
Ash.
Drilling and wiring the lock nuts seems the easiest to do. Perhaps some one, with some engineering knowledge, at VOSA has twigged that once welded the
unit is effectively foobared
posted on 27/5/10 at 11:28 AM |
I've often wondered whether welding the bias bar would weaken it in any way...
