main82000
posted on 11/6/10 at 10:26 PM |
sierra caliper
hello all
does anyone on here have a spare left hand side rear caliper for cheap sale all i need is the part that gets bolted to the car
the caliper is a solid disc one
i was bolting it on to the car tonight and the bloody bolt snapped in side and i have tried everthing to get it out
hope you understand what im on about
cheers craig
[Edited on 12/6/10 by main82000]
![](/galpreviews/a1162834-sierra caliper.jpg) ![Rescued attachment sierra caliper.jpg](/gallery/a1162834-sierra caliper.jpg) Rescued attachment sierra caliper.jpg
mcerd1
posted on 11/6/10 at 10:34 PM |
solid or vented rear discs ?
I don't think they are handed (will check tomorrow)
I've got a solid disc one with a pin sheared off in it (should drill out) you can have it for nowt +P&P
assuming I can get the bit of pin out of it.... (or your welcome to try yourself)
[Edited on 11/6/2010 by mcerd1]
hobbsy
posted on 11/6/10 at 10:36 PM |
I had similar happen on a mates Westfield.
If you've got a suitable tap drill it out to the size you would to tap it in the first place then run the tap through it.
Just make sure you're central.
mookaloid
posted on 11/6/10 at 10:51 PM |
won't the old 'migweld a nut on the end of the sheared stud' technique work?
main82000
posted on 12/6/10 at 10:47 AM |
hi
no the bolt snapped flush so i have tried drilling, heating,extractor set and when i drilled went a bit wonky not to bad i think dont know still
cant get it out so i think replace it as it is the brakes
also cheers mcerd1 will take you up on that thanks again
craig
mcerd1
posted on 12/6/10 at 03:18 PM |
do you want me try and get the bit out before I send it ?
main82000
posted on 12/6/10 at 03:32 PM |
hi again
yeah that would be great if you can but dont worry about the state of it ill soon clean it up i think im goin to powder coat it
it wont let me u2u you ill try again later
cheers craig
