daniel mason
| posted on 2/10/10 at 06:02 PM |
good day in the garage, bodywork fits great
i had a good day in the garage today fitting body panels,header tank,fuse panel etc!
i must say the mnr fibreglass bodywork is of excellent quality and fits absolutely spot on! the pannels are an excellent fit and all the gaps between
pannels are even and very close!
  bodywork
  engine bay
[img][/img]
daniel mason
| posted on 2/10/10 at 06:08 PM |
its slowly coming together now
[img][/img]
RichardK
| posted on 2/10/10 at 06:10 PM |
Nice looking motor btw, always heard nothing but good comments about MNR so not surprised.
A good mornings work, does that count!
I made a jig for chopping my blacktop sump, went overboard as usual but its there to loan to others if it turns out good!
Few more in my gallery below.
Rich
[Edited on 2/10/10 by RichardK]
Gallery updated 11/01/2011
| posted on 2/10/10 at 07:22 PM |
That's coming on very well Daniel.
Refreshing to see a non Black chassis too
| posted on 2/10/10 at 07:26 PM |
It's Evolution Baby!
stevegough
| posted on 2/10/10 at 09:30 PM |
Nice fit, Daniel, looks good..... I like the yellow chassis, too - there's a few of us non-black chassis guys around!
[Edited on 2/10/10 by stevegough]
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
stevegough
| posted on 2/10/10 at 09:33 PM |
Rich
Sump chopper looks ok, Richard - appreciate it needs to be cut straight, but how is it going to reach at the ends?
Luego Locost C20XE.
RichardK
| posted on 3/10/10 at 09:14 AM |
It does go around the corners just, I plan to put a couple of blobs of weld around the cut line on the front end that will act as a guide for the
hacksaw on the bit in the middle of the end that the cutting wheel can't get to. The other end will be built up so it will go around that end.
This should ensure it all stays flat.
Only going to do the cut after I've built up the shallow end, hopefully this will preventing it warping with the welding a little if in remains
intact until the last moment, no gaps should mean minimal pulling so should minimise warping which is my main reason why I'm doing this!
Does seem a little excessive though!!
Rich
Nash
| posted on 3/10/10 at 12:48 PM |
Yellow is definately the way to go. But then I am bias. This is from a couple of years ago
  front end first fix
.....Neil
Build It, Buy It, Drive It:
Southern Kit Car Club
