daniel mason
posted on 22/1/11 at 09:24 PM |
more progress and rear exhaust design! following on
following on from my rear exhaust thread, please take a look in my blog and look at my design idea. i think am going to go ahead with it,but wanted
some opinions first. i know i need some heat shields making, and some mods to bodywork to prevent damage from the heat!
blog underneath!
Dangle_kt
posted on 22/1/11 at 09:30 PM |
is that the fuel tank?
Its different, i'll give you that!
mistergrumpy
posted on 22/1/11 at 09:42 PM |
I can't get orientated with the first 2 pictures. Am I right in thinking the exhaust comes up through the floor behind the drivers seat and then
through the rear bulkhead panel?
Thinking about it
posted on 22/1/11 at 09:48 PM |
Then up over the fuel tank
daniel mason
posted on 22/1/11 at 09:50 PM |
thats right. i wanted the silencer as far away from my ear as possible, and as the bore is 63mm there is no room for it anywhere else! i put a thread
regarding exhaust gasses and safety yesterday and the general outcome was go for it. so i am!
daniel mason
posted on 22/1/11 at 09:59 PM |
something like this
mistergrumpy
posted on 22/1/11 at 10:03 PM |
Yep. Nowt wrong with being different It may get a bit warm behind you though!
daniel mason
posted on 22/1/11 at 10:09 PM |
i know! heat wrap and a heatshield there too!
tomgregory2000
I fail to see why people are getting woried about an exhaust being close to a fuel tank.
Have a look under most tintops and the exhaust is rather close to the fuel tank
se7en
posted on 22/1/11 at 10:11 PM |
Daniel on a different item.
Are your Fog and Reverse lights mounted on the right sides?
AFAIA the Fog should be on the off-side.
Tom
daniel mason
posted on 22/1/11 at 10:18 PM |
thats a questioni dont even know the answer too! ^^^
i thought they needed a minimum of 100mm seperation from rear cluster. but not sure if lights sould be on certain side? can anyone clarify this
point?
also the pipe is a good 6" away from tank it this situation. a lot further away than it was in the donor s2000
[Edited on 22/1/11 by daniel mason]
MakeEverything
posted on 22/1/11 at 10:33 PM |
Ditto. I think its a pointless worry. If the fuel lines were tied to the exhaust, id say yes but theyre not.
Good luck anyway. I like things different.
Kindest Regards,
Richard.
daniel mason
posted on 22/1/11 at 10:40 PM |
thanks richard. your build is looking good by the way!
MakeEverything
posted on 22/1/11 at 10:50 PM |
thanks! I didnt think anyone was reading it! I havent had any critiques from L0rd for a while either!!
Kindest Regards,
Richard.
StrikerChris
posted on 22/1/11 at 11:01 PM |
If i remember right the fog light can be anywhere from dead centre to anywhere towards the offside,then all the carp, so far from your other lights
etc.dont see a problem with the exhaust either,except you getting hot,alu conducts heat super quick so the heatshields will soon get as hot as the
exhaust remember!loudest thing in my car is not the exhaust but the wind,both straight down my ear,and from most passengers arse's tho.
se7en
posted on 22/1/11 at 11:40 PM |
Daniel
The information about the Fog Lamp can be found in section 28 of the IVA Manual
"At least one must be on centre line or to offside of vehicle (Min separation distance from stop lamp 100mm)"
Tom
daniel mason
posted on 23/1/11 at 11:20 AM |
I can't imagine the wind being as loud as the buddyclub mate, and the wind isn't too bad in the Mnr. The ally heatshield will not be
touching the exhaust anywhere and I will lag the exhaust in heat wrap and insulate the ally with that heat proof sheet!
MakeEverything
posted on 23/1/11 at 09:51 PM |
Any progress Dan? Im really interested to see the finished prototype and hear it running.
Kindest Regards,
Richard.
RichardK
posted on 23/1/11 at 10:19 PM |
Ok, I'm up for being different but to be honest I don't like it, unless I looking at it in some way incorrectly.
So is that the exhaust exit above the rear arch?
Usually exhausts are pointing out and down towards the road/kerb not at toddlers heads and pushchair height.
If its a track car then cool If a road car then I'm not a fan. Soz mate.
Rich
Gallery updated 11/01/2011
daniel mason
posted on 23/1/11 at 10:35 PM |
it is an angled pipe mate and does point down. although not as much as a standsrd kit type silencer. no progress today but next week i will hopefully
have it cut to correct length ready for welding!
adithorp
posted on 23/1/11 at 10:38 PM |
Couple of comments...
Looks like you're bringing it up through the floor? Won't that mean it's very close to the ground?
Rear fog needs to be moved to the other side as others have said. The lamp also needs to be mounted so the lens is vertical (not just close to).
Don't take this the wrong way but... I'd suggest that reading the relevant bits of the manual before bolting parts on, can save a lot of
"redoing" and retest fees later.
http://jpsc.org.uk/forum/
RichardK
If it turns the gases to the rear then cool but still slightly concerned about the height of the gases.
R
[Edited on 23/1/11 by RichardK]
MakeEverything
posted on 23/1/11 at 10:59 PM |
R
Its no worse than some buses ive seen.
Kindest Regards,
Richard.
daniel mason
posted on 23/1/11 at 11:05 PM |
i'll switch the fog and reverse light around in the week. and try to get it as close to vertical as possible.
Davey D
posted on 24/1/11 at 10:34 AM |
Got to say i really dont like the look of the exhaust coming out like that. Once the car is up and running the whole area around the arches is going
to look a dirty sooty mess with all the exhaust gasses blowing out onto them
