Author: Subject: MNR Windscreen
cerbera
posted on 30/1/11 at 02:25 PM Reply With Quote
MNR Windscreen
I'm finally getting round to fitting my new screen but it doesn't seem to want to sit naturally and I am having problems trying to find the best fit.
Of those who have fitted a screen what dimensions have you used for the 2 fixing holes either side? If you could give me the measurements from the front edge of the scuttle and the lower edge it would be appreciated.
Cheers in advance.
Agriv8
posted on 1/2/11 at 07:43 AM Reply With Quote
Hi Cerbara.
Providing you are not 6'6" like me the bottom of the mounting brackets should be parallel the the base od the scuttle with this in mind its just a case of moving the screen back and forward.
I have gained a few more MM on mine buy tilting the screen forward slightly so the measurements on mine will be of no use to you.
Was due to nip over and see marc tonight but a 3 week old insomniac means I had better get home a some Kip.
Have you tried emailing marc as i am sure one of the cars in the workshop has a screen fitted ?
Regards
Agriv8
cerbera
posted on 1/2/11 at 12:19 PM Reply With Quote
Cheers for the reply Agriv8, will email Marc.
