Author: Subject: engine oil
iain b
posted on 12/4/11 at 06:53 PM Reply With Quote
engine oil
what /where will i find the oil you use when putting an engine together.also how long will it last before the engine is finally used ........thanks for any replies folks........
mcerd1
posted on 12/4/11 at 07:01 PM Reply With Quote
do you mean 'assembly lube'
you can get it from most of the usial suspects
eg. burtons: http://www.burtonpower.com/catalogsearch/result/?q=assembly+lube
not sure its really needed for a normal engine - as to how long it lasts, mine is still covered in the stuff and my engine has been laid up for over a year now...
[Edited on 12/4/2011 by mcerd1]
cliftyhanger
posted on 12/4/11 at 08:09 PM Reply With Quote
I spoke to a machine shop who said they used gear oil. Think it is good as it is EP spec stuff, so maybe resistes initial dry startup better?
Otherwise I have always used engine oil, but cam lube on the cam (OHV engine, so different requirement to OHC)
I do spin the oil pump before startup with a drill, get the pressure to working levels. Again the OHV makes this possible
amalyos
posted on 12/4/11 at 09:17 PM Reply With Quote
Iain, don't tell me your starting your new MNR build with the engine first
http://stevembuild.blogspot.com
iain b
posted on 12/4/11 at 10:34 PM Reply With Quote
no no noi
i have a spare engine for the cobra ,it has been stood for three years so thought i would give it a look over.ended up taking it completely to bits .all in gooooood order ,but as it may not get used staight away was woundering what oil to use for rebuild so i do not end up with a sized engine...........i will size it up myself by driving it to death................
robinj66
posted on 12/4/11 at 10:46 PM Reply With Quote
I've always used the STP oil additive - the stuff that is like treacle - for rebuilds including the bearings plus cam lube for the camshaft
such as Oil Treatment For Petrol Engines STP 450ml NEW | eBay UK
[Edited on 12/4/11 by robinj66]
