Author: Subject: how to mount the clutch pedal
daniel mason
posted on 5/7/11 at 08:26 PM Reply With Quote
whats the best way to couple the clutch pedal to the master cylinder?
i am using the mnr pedal box and pedals and wilwood master cylinder, and if a clevis was wound on to the thread of the cylinder and pinned to the padal it would throw the pedal way too far forward! is there a possible way to shorten the threaded rod on the master cylinder without removing it, (space is very tight in the footwell). as to remove it would mean removing brake fluid resevoir,clutch cable,all steering components to get access due to the limited space with the honda engine/box! cheers.
Agriv8
posted on 6/7/11 at 09:31 AM Reply With Quote
pah no room you want to see mine !?!
not sure but I would
drop pedal forward ? wind the nut on ( to clean treads after cutting ) hold bar with vice grips and dremmel off with a small spinning cutter.
regards
Agriv8
