daniel mason
posted on 26/12/11 at 06:19 PM |
front end suspension setting advice needed please
i am purchasing a gunson trackrite wheel alignment gauge to set the car up properly next week so;
1; what is a standard ride height at the front end? or is it dependant on wheel size?
2; how do i set in board shocks correctly to correct height (do i adjust ride height with shocks or pushrods)? and how many clicks from full clockwise
on dampers?
3;am i right in thinking the rear needs to be about 25mm higher than the front?
4; whats the optimum toe in and camber on front wheels?
5;whats the optimum set up for the rear track,toe and camber?
thanks for any help!
[Edited on 26/12/11 by daniel mason]
T66
posted on 26/12/11 at 09:37 PM |
Ive got a word document on suspension setup, found it recently,
Ive emailed you it.
Ivan
[Edited on 26/12/11 by T66]
daniel mason
posted on 26/12/11 at 10:16 PM |
thanks ivan. ive had a quick look. but is there any referance points to start from on the mnr?
RickRick
posted on 4/1/12 at 09:19 AM |
make sure you have the push rods long enough to allow some droop on the front wheels, i started out with the pushrods too short, got the ride hight
correct, but if i jacked the car up the wheels were off the ground in the first 20mm and it felt like the front was really hard, extend the pushrods
and wind the spring seats down to get back to the same ride hight. i think i went for 100mm front and 130 rear ride hight. i've got a note of
the pushrod length at home, but it depends which way up you have your lower wishbones
daniel mason
posted on 4/1/12 at 08:27 PM |
^^^^u2u sent mate. thanks
big_l
posted on 6/1/12 at 12:22 AM |
surely if you have the wisbone the wrong way up then the outer ball joint will rip the c clip out and fall to bitts ???
Check out my blog mnrvortxhayabusa@blogspot.com
RickRick
posted on 6/1/12 at 07:31 AM |
I think mine was built about the time there was some issues over which side the circlip should go on but it's 3 years ago now i think.
Dan i forgot to check for you last night but i'll get on to it when i get in tonight
daniel mason
posted on 7/1/12 at 07:36 PM |
the wishbones can only go one way uo as the circlip would be holding up the front end and fall to bits
RickRick
posted on 10/1/12 at 11:21 AM |
my push rods are 445mm long but the mountings are on top of the wishbone (but the circlip is on the bottom of the wishbone)measured at the position
of the front of the front wishbone i've got 100mm ground clearance. However the thing that made a big difference to how it handled was making
sure it had plenty of droop. so when i jack it up till the front wheel just leaves the ground the same point at the front of the front wishbone is
150mm from the ground. I'm not going to say this is right it's not been setup by a pro but it works for me
