Author: Subject: BEC Gear Lever mode?
westindy
posted on 29/12/11 at 10:13 AM Reply With Quote
Can someone tell me the set most used for your gear lever position - eg 1st is gear lever pulled back and 5 gears push lever forward or the opposite. just setting up my linkage now and people seem to have both setups?
Rgds, Paul.
daniel mason
posted on 29/12/11 at 10:26 AM Reply With Quote
i prefered 1st = push then pull back for the rest if using stick shift,but i prefered the paddleshift setup and klicktronic shifter on my last car
A1
posted on 29/12/11 at 10:45 AM Reply With Quote
i used back first then forward for the rest. would maybe prefer it the other way but im used to it now
cerbera
posted on 29/12/11 at 11:24 AM Reply With Quote
On my old BEC first was forward then the rest were back.
HTH
stevec
posted on 29/12/11 at 11:30 AM Reply With Quote
I did 1 forward and five back on my previous engine, its probably easier to pull back when accelerating than to push.
Steve.
posted on 29/12/11 at 11:34 AM Reply With Quote
I use push to downshif, pull to upshift. When accelerating you are pushed back in your chair and then it's easier to pull backwards and equally when you're decelerating and straining the straps it's easier to push forwards to downshift.
bowood14
posted on 29/12/11 at 11:39 AM Reply With Quote
Mine was back first then forward the rest didn't get on with it so have it forward 1st then back rest much more natural flow as already said above
ReMan
posted on 29/12/11 at 01:04 PM Reply With Quote
Yep wot he said 4 sure
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
matt_gsxr
posted on 29/12/11 at 01:24 PM Reply With Quote
pull to upshift.
fullpint
posted on 29/12/11 at 01:45 PM Reply With Quote
Mines pull up for first (left side of paddle) and then up again (right side) to go thru the box..
On the shift stick it's back one for 1st then bang it forward to go up thru the box..
I've over 28 years in dealing with magnesium wheels. Refurbishment and can powder coat most metal parts. Visit my web site if you wish..
www.tpcs-magnesium-refurbs.co.uk
MikeFellows
posted on 29/12/11 at 05:13 PM Reply With Quote
erm.....
I can adjust this?
mad-butcher
posted on 29/12/11 at 05:51 PM Reply With Quote
As BenB and most others
