daniel mason
posted on 13/1/12 at 05:46 PM |
had my rear exit exhaust done today!
i have finally found someone decent and willing to modify my honda s2000 spoon N1 exhaust system for a rear exit set up on my mnr.
after a post on here i went to darlington to exhaustafix. very helpful,full of good ideas,and good service.am very happy and have loads of ground
clearence under back axle.sounds quite tasty too! all in all a good day an am pleased with the system. they cut the original pipework from the spoon
exhaust and fit a new stainless system,and then welded the new piping too existing silencers. there is a centre box which is where a standard kit car
silencer would be,then the piping goes through rear arch and under back axle.
pics to follow
daniel mason
posted on 13/1/12 at 05:54 PM |
twybrow
posted on 13/1/12 at 06:08 PM |
I must say I'm not a fan.... I cant see the advantage - if I was going to the expense of having s rear exit zorst, I would want it to run the
length of the car within the chassis just like a tin top, rather than having a regular kit zorst, that then goes back under the car, and exits at the
rear... Was the aim just to use as much of the original as possible?
daniel mason
posted on 13/1/12 at 06:11 PM |
main aim was to get silencer away from my right ear really. i understand its not to everyones taste,but the spoon N1 is a good setup designed for the
s2000 which is sensitive to exhaust change.
Davg
posted on 13/1/12 at 06:13 PM |
Sorry mate have to say
Won't be missing too many speed bumps with that one then!
Never mind geeting it on the ramp for IVA!
cheers
D
blakep82
they've done a cracking job, and they've done what you asked for, and i do like to see a rear exit exhaust, but have to agree, it runs
along the side of the car already, could only see the benefit if it ran through the tunnel too.
quite snug under the fuel tank too! hmm yeah, not really working for me either sorry
[Edited on 13/1/12 by blakep82]
________________________
daniel mason
posted on 13/1/12 at 06:18 PM |
if that hits a speed bump at 6" from the ground it will be the least of my troubles. only got 85mm under the sump. lol!
Davg
posted on 13/1/12 at 06:22 PM |
Ah well no worries then you'l be flying by then
daniel mason
posted on 13/1/12 at 06:23 PM |
^^^ lol.
myke pocock
posted on 13/1/12 at 07:01 PM |
Are they able to make up full manifold systems as well? If so can you post a link or send a phone number please.
plentywahalla
posted on 13/1/12 at 07:15 PM |
This is an interesting thread because I have been trying to work out a rear exit exhaust. My plan was to run twin pipes from the pre-cat under the
floor pan in oval stainless tube, then up behind the rear bulkhead and over the half shafts. Its then that it gets problematic as I need to decide how
to locate the main Cat and silencer and fuel tank.
The obvious location is a transverse box behind the rear valance, but it causes problems with the location of the fuel tank. I either locate the tank
above the rear axle (de dion) which means that the tank size is limited and I get no stowage space. Or I locate the tank above the catalyst which is
very hot and (maybe!) not a good idea.
Apologies for hijacking this thread ... but I have been thinking of asking this question and it seemed a good opportunity.
Rules are for the guidance of wise men ... and the obedience of fools. (anon)
daniel mason
posted on 13/1/12 at 07:24 PM |
Check indybird on here. He did a similar thing to me with his Mnr. Which is where I got the inspiration. Pics in his archive
also they don't do manifold in house unfortunately. I originally tried ass in Newcastle after recommendations but they refused to work on my
car unless they supplied the silencers. Which was a shame because I wanted to use the ones I had
bi22le
posted on 13/1/12 at 08:40 PM |
Donkervort have a side exit exhaust and then it carries onto the back of the car with twin exit.
They cost £60+!!
Please read my ring story:
Dusty
posted on 14/1/12 at 12:14 AM |
I think it looks fine. Two silencers and a longer run of pipe. Should be nice and quiet. Doubt you will get chucked out of any trackdays for too much
noise. Noise has always been one of my issues and I'm thinking of going a similar route. The only problem is where to fit a transverse silencer
without moving the tank and losing some of the boot space. I wonder if you can get a custom oval exhaust only about 3 inches deep? Maybe I should have
it pointing straight up like a tractor!
daviep
posted on 14/1/12 at 01:16 AM |
I would think that the cat would be too far from the engine to get hot enough if you put it all the way to the back of the car, just a thought.
Davie
beaver34
posted on 14/1/12 at 08:44 AM |
have people ever run them in the floor pan? you could put it in the middle down the passenger side
loggyboy
posted on 14/1/12 at 08:56 AM |
They cost £60+!!
Only £60! il have a few of them!
dave107
posted on 18/1/12 at 01:36 PM |
Just be careful when filling up with fuel drip drip bang.
posted on 18/1/12 at 05:38 PM |
Although petrol is highly flammable it needs a naked flame or spark to ignite the vapour. Petrol dripping on a hot exhaust will just smoke a bit.....
Phil
thestoat
posted on 18/1/12 at 08:42 PM |
Have I arrived at the wrong forum?
As someone who is struggling with noise levels looks like a good idea to me.
bi22le
posted on 18/1/12 at 09:25 PM |
Being a Londoner that has visited newcastle i must mention there is some mighty fine ass up there.
sorry, am i in the wrong forum!?!
daniel mason
posted on 18/1/12 at 09:34 PM |
lol! ^^^
advanced automotive solutions i think they are called!
first350
posted on 19/1/12 at 09:40 PM |
any pics of the rear from farther away? I like the idea...
Toprivetguns
posted on 19/1/12 at 09:58 PM |
Looks good ! Glad to see it turned out how you wanted it.
Only drive as fast as your angel can fly... !
daniel mason
posted on 19/1/12 at 10:29 PM |
Thanks guys. It's how I wanted it so can't complain. What pics do you want me take mate. Will do some this weekend
there's one from a bit further away On first page of my blog if you want to look
[Edited on 19/1/12 by daniel mason]
