Author: Subject: Fury steering column lower rubber joint
mazie
posted on 5/2/12 at 04:12 PM Reply With Quote
Hi all, had to remove the lower steering column section that connects to the rack. The rubber joint that connects the two halves has cracked and needs to be replaced but i can't seem to find a kit anywhere. unable to load a picture yet ( stupid iPhone!) Ive drilled out the old rivets holding it together .
I hope my terrible description makes sense !
clairetoo
posted on 5/2/12 at 04:18 PM Reply With Quote
I doubt that you will be able to replace the rubber - best to replace the whole thing with a proper metal UJ .
Its cuz I is blond , innit
Claire xx
Will weld for food......
stevec
posted on 5/2/12 at 08:13 PM Reply With Quote
Go to Dave Mac propshafts in Northey road Coventry, ask for John. He will sort it for you.
http://www.davemacprops.com/DMPHOME.html
Steve.
