AndyW
posted on 28/6/12 at 05:27 PM |
dash layout opinions please
Hi guys n gals,
I now have my new Acewell 3251 dash and need to think about the position on the dashboard. What are peoples opinions on the position, should I put it
central on the dash or behind the steering wheel. I prefer central and just wanted to see what your thoughts are and any pro's and con's.
Here is the dashboard at the moment.
big-vee-twin
posted on 28/6/12 at 05:36 PM |
I'm just doing the same as you, although my gauges are traditional type, all my clocks are going in the middle with my warning lights behind the
steering wheel.
[img]
Steering Cowl trial fit
[/img]
[img]
Guages for Dash
[/img]
http://www.triangleltd.com
AndyW
posted on 28/6/12 at 05:38 PM |
Nice clocks!!
MsD
posted on 28/6/12 at 05:40 PM |
Id personally go for the middle of the dash, just be careful of your radius projections for iva- I've recessed mine back and will be putting a
thin piece of clear plastic I front of it (just so he can't get his radius sphere near it).
I wouldn't choose behind the steering wheel- if you changed the wheel in the future you might not be able to see the display...Hth, Mark.
steve m
posted on 28/6/12 at 05:43 PM |
I prefer the clocks!
lewis
posted on 28/6/12 at 05:49 PM |
I'm doing the same Acewell in the middle & shift lights behind the steering wheel,I'm already on the road though so you need to bear
that in mind.
I am a driving god!..........sort of
twybrow
That is the problem I have. It works really well with my current 12", but I am changing to a 10" wheel, and it obscures the dash meaning I
have to make another CF dash to move the clocks to the centre... dammit.
Rod Ends
posted on 28/6/12 at 06:05 PM |
Blingy Bling Bling!
jacko
posted on 28/6/12 at 06:53 PM |
http://www.locostbuilders.co.uk/forum/30/viewthread.php?tid=64223
there you go fill your boots
austin man
posted on 28/6/12 at 07:54 PM |
steering cowl
AGM motorsports do the sierra cowl to fit the acewell behing the wheel so if your cowl is no good worth a look
Stott
posted on 28/6/12 at 08:17 PM |
I've got a very similar dash to you with a centre console below with savage switches in, and a 3251
I put mine in the centre as I didn't feel I could see it through the 10" mountney wheel I've got. I made a bracket to hold it behind
the dash slightly so the warning light surround protrudes by about 2-3mm, it looks good.
Edit: this is because the warning light surround fails radius tests
As a separate point, the way you have your savage switches mounted will fail IVA radius tests. You have to ditch the aluminium body/spacer and they
mount flush in which will pass.
HTH
Stott
[Edited on 28/6/12 by Stott]
Slater
posted on 29/6/12 at 07:03 AM |
Best way for you to test this is to photocopy the gauges/switches and any other things you will have on the dash, cut them out, then use blutac to try
out different positions. It's best if you sit in the the drivers seat to try them out. This is what I did.
loggyboy
posted on 29/6/12 at 08:13 AM |
I really want my rev gauge and possibly speedo right in front of me, however sometimes its just not possible on these cars due to the size of wheels
and dash.
Its really down to personal preference, but I will definately be targeting getting mine behind my wheel.
Mistral Motorsport
Alan M
posted on 29/6/12 at 08:50 AM |
My car went through SVA with the Acewell unit mounted in the centre of the dash but when using the car it is not easy to see, so I moved mine to
behind the steering wheel; much better
FuryRebuild
posted on 29/6/12 at 11:51 AM |
the secret is symmetry
Things of interest are that the second gauge in from the left is a triumph multi-indicator dash dial, that shows indicators,
oil, headlights, etc. They’re very rare now, and I couldn’t even find a photo on ebay to show you what they look like up close.
I did try hard to get a good-looking layout, and the secret for me was symmetry. The difficulty was that the wiring harness was
designed to put all the gauges in a line, rather than where I wanted them (i.e. no gauge obscured by the steering wheel, etc). As
such, the harness had to be chopped and extended extensively behind the dash.
The tacho is behind the steering wheel and canted over so 7500PRM is vertical.
Finally, watch out for the electronic gauges. I found that the vibrations when racing eventually knacked most of the electrical
gauges such as oil pressure, so I replaced them with mechanical capillary gauges from VDO. Definitely worth the investment.
www.furyrebuild.co.uk
loggyboy
posted on 29/6/12 at 12:07 PM |
Similat to one of these?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&_trksid=p4340.l2557&hash=item416716429b&item=280902386331
or
http://img.photobucket.com/albums/v206/streets/7a_1_b.jpg
[Edited on 29/6/12 by loggyboy]
Mistral Motorsport
FuryRebuild
posted on 29/6/12 at 12:09 PM |
Not similar, exactly the same
I've owned a couple of triumphs in the past and loved the convienience and simplicity of these gauges.
AndyW
posted on 29/6/12 at 04:51 PM |
HTH
Stott
Thanks for the advice. Its amazing that the switches in that position will fail. I will change them to the correct way.!
ceebmoj
posted on 3/7/12 at 08:35 AM |
I prefer the instruments to be straight in-front of the driver because I find it far easer to glance at them there rather than looking to the centre
of the car. if you cant fit the instruments in that position then see if you can get warning lights there at least.
FuryRebuild
posted on 3/7/12 at 09:22 AM |
ceebmoj - I agree with you.
there's been a lot of ergonomic study done about the time it takes to process this information, and how the brain works. My tacho (ETB, not the
smiths one in this photo) is canted over to show the needle vertical at 7500 RPM - I can see this out of the lower periphery of my vision. I think
this is why even electronic gauges offer some kind of analogue analogue - moving scales, etc.
Processing a number requires a different route through your brain (and takes longer) than processing a simple visual signal (hence shift-lights).
For me, the key gauge is right where i need to see it (right behind the wheel) and it was also as large as I could sensibly shove in there. As part of
the rebuild I'm even tempted to craft a hump in the dash to raise it again.
Saying that, I'll also coat it in something flocked or alcantara rather than shiny black (which I painted matt black the day after i drove the
car in the bright sun).
