Chaz
posted on 31/7/12 at 07:22 AM |
Submerged my IPhone in water - but it's fine!
Well done Apple you have now completely impressed me!
After bathing my son I was clearing up his bath toys when my iPhone slipped out my top pocket into the water. Was fully submerged for 2-3 seconds
before I rescued it. I heard an electrical buzz that went through the water!! Took it out and shook it - lots of water came out. Left it to dry out
about 8 hours and now it works perfectly!
I'm posting this topic from my IPhone!
Happy days
stevegough
posted on 31/7/12 at 07:34 AM |
Wife dropped her Nokia XperssMusic down the toilet. I retrieved it a couple of mins later - it didn't work, stripped it down into about 12
pieces, dried each bit, re-assembled it - it worked......
.....for about 3 months, then it suddenly died permanently
So - don't count your chickens!
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
Xtreme Kermit
posted on 31/7/12 at 07:35 AM |
That's a result, let's hope it stays that way. Airing cupboard and bags of rice are good for drying wet phones.
balidey
posted on 31/7/12 at 07:38 AM |
Sounds like a lucky escape.
One thing to bare in mind, I am told there are 'water detectors' inside the phone, so if you intend to sell it on at some point, this is a
visible sign its been wet so it could harm your resale value.
Dutch bears have terrible skin due to their clogged paws
Jon Ison
posted on 31/7/12 at 07:44 AM |
Swimbo's iPhone failed the left in pocket and put in washing machine test, guess that was a little more rigorous
scudderfish
posted on 31/7/12 at 07:53 AM |
It also means that you are basically screwed if you have to take it back for repair now, even if it isn't related to it being dunked.
GOJO
posted on 31/7/12 at 08:00 AM |
I would put it in some rice to pull any moisture from it electrical circuits usually fail when the moisture has corroded the circuit no when there
just wet could be fine but it could be a fiew days before you notice a fault
jossey
posted on 31/7/12 at 08:24 AM |
Anyone seen them bags on gadget show which dry your phone out .....
http://www.save-a-phone.co.uk/
I think I want one of them... They worked well.
Omg I'm bored...
David Johnson
Benzine
posted on 31/7/12 at 09:54 AM |
did you retrieve the phone by Apple bobbing? *dun dun ttttsssss*
posted on 31/7/12 at 10:49 AM |
+1
twybrow
posted on 31/7/12 at 12:51 PM |
the last phoen I dropped in water, worked fine straight afterwards. then a couple fo weeks later developed a minor fault, and then 3 months later
packed up completely. It will have done damage - the question is when it shows itself!
