Apollo1600
posted on 30/12/12 at 12:01 PM |
Sump problems
Im struggling with my pinto sump. As far as i can tell its a standard non shortened sump as i cant see any welds or joins. The problem i am having is
when i fit the sump it hits the pick up pipe. Could it possibly be a rs2000 pickup pipe? Its a real strange one! Any ideas?
MsD
posted on 30/12/12 at 12:09 PM |
Is it the standard Pinto sump or the RS2000 alloy sump?
You sure that the pick up pipe isnt bent/ fitted incorrectly?
Mark.
perksy
posted on 30/12/12 at 12:37 PM |
Be worth posting a photo if you can
Apollo1600
posted on 30/12/12 at 06:05 PM |
[img] [/img]
The sump is a standard pinto item by the looks of it and not a rs2000 one. How much clearance should there be between the sump and the pickup? You
cannot bolt the sump down as the pick up pipe hits the top of it!
posted on 30/12/12 at 06:21 PM |
Did the Pinto sump come as a front well and a rear well depending on what it was fitted to??
Apollo1600
posted on 31/12/12 at 11:05 AM |
Managed to get some better pictures this morning, hopefully they should
help!![](http://i586.photobucket.com/albums/ss308/driftking72/P1080411_zps61aa2bc4.jpg) ![](http://i586.photobucket.com/albums/ss308/driftking72
/P1080410_zps715c31b8.jpg) ![](http://i586.photobucket.com/albums/ss308/driftking72/P1080409_zpscac4b598.jpg) ![](http://i586.photobucket.co
m/albums/ss308/driftking72/P1080408_zps48406520.jpg) ![](http://i586.photobucket.com/albums/ss308/driftking72/P1080407_zpsb05a8587.jpg)
Apollo1600
posted on 31/12/12 at 04:05 PM |
Could it possibly be a 1600 pickup pipe as these are bigger? It's a real pain!
Apollo1600
posted on 1/1/13 at 11:49 AM |
Anyone?
alladdin
posted on 1/1/13 at 01:52 PM |
have you used a tape to check total hight of strainer from block/sump flange ? that will determine if its hitting the base or if maybe the bracket
is hitting the windage bridge.
jacko
posted on 1/1/13 at 04:29 PM |
I cant remember seeing that thin bracket across the sump on mine
