pekwah1
posted on 16/1/13 at 02:53 PM |
Headlight relays
Hi guys,
I'm getting all confused over relays.
I currently have sierra switchgear (i believe switched earth) and am thinking of changing to an escort switchgear instead (switched positive?).
My headlight relays are wired for the switched earth, so to change to a switched live, can i just change the permanent live that i have in my relays
to permanent earths instead and then wire up the switchgear?
Hopefully this makes sense...!
Regards,
loggyboy
posted on 16/1/13 at 02:55 PM |
Are they 3 pin relays with a shared earth?
Mistral Motorsport
pekwah1
posted on 16/1/13 at 02:56 PM |
4 pin, 30, 85, 86, 87
loggyboy
posted on 16/1/13 at 02:58 PM |
So you only need to change what wires go to pins 86 & 85, the rest can remain the same.
I hope!?
Mistral Motorsport
pekwah1
posted on 16/1/13 at 03:07 PM |
so can i just change 85 to a hard earth and then use 86 as a switch live from the stalk then?
sounds too simple, i don't like it! :p
loggyboy
posted on 16/1/13 at 03:36 PM |
This is how read it -
Currently the positve feed is to the the switch which connects to pin 85 or 86 and then the opposing 85/86 then goes to earth -
However the new set up needs a feed from 12v+, through 85 or 86, then out 85/86 to your switch which is earthed.
The 30 87 pin that switches the light on is unaffected by 85 or 86 as all it knows is if 85/86 is on or off.
Mistral Motorsport
pekwah1
posted on 16/1/13 at 03:37 PM |
so as long as 85/86 are completing a circuit (positive to earth) then it will work.
That makes sense, so by that logic then i can just swap round 85 and 86!
loggyboy
posted on 16/1/13 at 03:49 PM |
Lol not quite, 85/86 are currently completing a link to earth, you need them to complete a link from positive.
You need to trace the lead that leads from 85or86 to earth and connect that to positive, then trace the lead that runs from switch to positive and
change it to earth.
Mistral Motorsport
snowy2
posted on 16/1/13 at 04:02 PM |
The relay won't care how its switched.....basically you have a live feed to the relay and up to a switch that earths it and you want to do the
oposite. simples.....earth the wire on the relay currently supplied with a live (85/86) and the other end still connects to the switch which in stead
of going to earth is now live....
sometimes you are the pigeon, most of the time the statue.
pekwah1
ok you're confusing me all over again now!
I am assuming that these (rubbish) diagrams below are both fine for the relay:
1.
+ (30)-----(87) to lights
+ (85)-----(86) -
2.
- (85)-----(86) +
loggyboy
posted on 16/1/13 at 04:12 PM |
You confusing yourself. Its not the relays that need anything changing. its where the wires go to before and after the relay.
Swapping the cables that go to 85 and 86 will do nothing.
Mistral Motorsport
pekwah1
posted on 16/1/13 at 04:14 PM |
i didn't literally mean swap the cables, i meant swap the polarity going to each point on the relay..
[Edited on 16/1/13 by pekwah1]
loggyboy
posted on 16/1/13 at 04:20 PM |
Thats the same thing!
Hope this helps?
Mistral Motorsport
SteveWallace
posted on 16/1/13 at 04:50 PM |
One version of the Sierra switch is
Pin 85 to the dip switch
pin 86 to fused live
pin 30 to fused live
pin 87 to the lights
The other version is
Pin 85 to earth (i.e - ve)
Pin 86 to the switch (which then connects to live via the other side of the switch)
Pin 30 to fused live
Pin 87 to the lights
I.e the difference between the two is in how the solenoid in the relay is wired. In the first case its the switch that goes to earth and the relay is
connected to the fused live live supply. In the second case its the switch thats connected to the fused live supply and the relay thats connected to
earth.
pekwah1
posted on 16/1/13 at 06:27 PM |
Nice one guys thanks for the help...
I'll have a play over the weekend and report back!
GOJO
posted on 16/1/13 at 07:35 PM |
Yes
