Dooey99
posted on 25/1/13 at 06:47 PM |
Zetec 1.8l flywheel skimming
How much should I get skimmed off my standard 1.8L flywheel? I can get it done very cheaply
Less weight more speed, more power more speed
If in doubt, give it a clout
emwmarine
posted on 25/1/13 at 06:50 PM |
I thought the 1.8 was pretty light anyway. I would be nervous about skimming without having it balanced. A big heavy thing spinning just by your legs.
Building a Dax Rush.
monck
posted on 25/1/13 at 06:58 PM |
ive also heard a lightened standard one can be dangerous how dangerous im not sure maybe just a small risk ?
If i remember to light it will be horrible on a road car and wont idle well ..
whitestu
posted on 25/1/13 at 07:57 PM |
The alternative is to get a 1.8 CVH flywheel and mount a trigger wheel on the crank pulley if you need it for ignition.
The CVH fly is about 2kg lighter than a 1.8 Zetec. The holes need drilling out though as the CVH bolts are smaller, but this is easy to do at home.
Stu
alladdin
posted on 25/1/13 at 08:38 PM |
taking some weight from the outside is fine, but you cant remove the holes unless switching to a trigger wheel.
on x/f and pinto flywheels its common to remove the outer "lump" on engine side of ring gear.
Dooey99
posted on 26/1/13 at 12:26 AM |
i have experience with flywheel skimming and no how to do it safely i just wondered if anyone else had done it and how much they had taken off
Paul Turner
posted on 26/1/13 at 12:21 PM |
A steel flywheel cost me less than £200.
Plenty of evidence that lightened cast flywheels can explode.
How much do you value your legs.
posted on 26/1/13 at 12:27 PM |
Picked my steel flywheel off of the bay for £40 including postage
alladdin
posted on 26/1/13 at 04:51 PM |
only reason for that is meat being taken from the main span, taking it from the large outer added section (for smooth running rep mobiles) will lessen
the stress on the rest.
Dooey99
posted on 9/2/13 at 08:07 PM |
If I was to take 4mm off the outer side, off the face where the clutch plate touches the flywheel would I need to leave the clutch mounting threads
standard or could I take 4mm of them aswell? If that makes sense
big_wasa
posted on 9/2/13 at 08:44 PM |
A picture of my 2.0 fly done by scholar engines.
![](/galpreviews/) ![](/gallery/)
