ElmrPhD
posted on 6/2/13 at 10:44 AM |
driver's side bulkhead panel vs pedal box position
Silly question, perhaps, but is there a definite consensus on which side of the bulkhead framework to mount the ali panel?
I have perused enough build blogs/sites to see that both sides (engine side or cockpit side) have been used. I've mounted mine on the engine
side, already, as that is what I was advised and it seemed like the master cylinders' output pipes would require severe bending to clear the
middle frame tube. But...now I'm wishing that I had done it the other way so that the pedals would not be soooo far from the driver's
seat/gearshift/steering wheel and have a little more space in the footwell.
I'm 5' 11" with perhaps shortish legs. Wondering if the effort to relocate the pedal box, MCs and especially to re-route the
rearward brake pipe is worth it.
Likely, it all revolves around the not-so-movable gearshift lever (MT75 box), but since my supplier is slower than molasses in January...I have no
idea.
Any thoughts?
Xie-xie,
Steve, in the NLs
designer
posted on 6/2/13 at 01:01 PM |
I always put the panel on the engine side. Then there are less corners for engine grim to get into.
big-vee-twin
posted on 6/2/13 at 02:01 PM |
Mine is on the cockpit side, it only moves the pedals in by 25mm, the pedal box I have is shaped to fit round the botton chassis rail presumabily give
a bit more stability.
I'm not moving mine though.
I would suggest you put it where you preffer now or it will continue to bug you forever, dont think it makes too much difference really.
http://www.triangleltd.com
