Author: Subject: Digital dash speedo
F1SJL
posted on 4/11/13 at 07:46 PM Reply With Quote
Digital dash speedo
Hi all
Looking to change my dash to an all in 1 digital unit.
Anyone have any suggestions or have one for sale
teegray19
posted on 4/11/13 at 08:55 PM Reply With Quote
Zx10-r. Really nice bit of kit.
I've got one for mine.
F1SJL
posted on 4/11/13 at 09:02 PM Reply With Quote
You mean the bike zx10r clock?
If so how easy to wire up?
Ste
teegray19
posted on 4/11/13 at 09:10 PM Reply With Quote
Yeah, mine is for a bec application so more suited but very easy to wire in.
I have the wire diagram if you choose to go that route.
F1SJL
posted on 4/11/13 at 09:18 PM Reply With Quote
Cheers mate.
Looks like a nice tidy unit.
Might look on eBay see if I can pick up a bargain. Hate the cluttered dash look. Starting hillclimb and sprints next year so cutting weight where I can!
teegray19
posted on 4/11/13 at 09:36 PM Reply With Quote
I got mine for 50quid with the multi plug.
Best bit of kit I've bought. Trip computer that is pretty easy to wire in.
I used the Fi warning for the hand break warning, bits like that... I was getting away from all the garages aswell!
teegray19
posted on 4/11/13 at 09:38 PM Reply With Quote
Zx12r.. Not ten.. All the wiring will be the same though.
wombat
posted on 5/11/13 at 07:45 AM Reply With Quote
So are you saying a bike dash will work with say a 2.0 Zetec etc.
Do you know someone who has done this?
eBay currently has Koso dash for £170.........
Smoking Frog
posted on 5/11/13 at 10:14 AM Reply With Quote
If fitting a bike speedo to a car engine the rev counter will rarely get past the halfway point. 8,000 rpm compared to 12,000 rpm for a bike. My koso clock has a range up to 10,000 rpm which is too great. The more the scale is suited to the engine the better it is to see needle movement.
davidimurray
posted on 5/11/13 at 10:52 AM Reply With Quote
I've got a KOSO DB02R with the extra tell tale lights - http://www.digital-speedos.co.uk/new-db02r-with-universal-indicator-kit-120-p.asp
It a good bit of kit but a few things to note, and this applies to a lot of bike type dashes.
Fuel sender must be either 100 or 510ohm resistance type, although you can now buy a box of tricks that supposedly allows any sender to be used.
On mine - if using MPH, the temps can only be in F
Half the tell tale lights are positive triggered and half negative triggered. This can be got around with some miniature relays.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
Rod Ends
posted on 5/11/13 at 02:00 PM Reply With Quote
There are some cheap Koso clones on ebay - anybody tried them?
stevio73
posted on 13/11/13 at 08:45 AM Reply With Quote
If the speed probe or pickup is from the sprocket on the zx10 and zx12's how easy is speed calibration in a bec application?
I'm very tempted by the zx12 clocks but the thought of then having 'magic boxes' to tweek the pulse to get an accurate speedo isn't one I like.
I assume on the KOSO clocks it's all internal and 'tweekable' being a universal fit?
Besides, the cheapest zx12 (or zx10 for that matter) clocks I can find locally at the bike breakers in Doncaster are talking £150+vat. I might as well go with the koso off fleabay for £160 delivered.
Quick as a flash...... Nothing happens!
